It is currently Mon Aug 18, 2025 4:13 am
PostPosted: Fri Dec 08, 2006 5:04 am
I was shopping online today, at US Plastics, to replenish my stock of small squeeze bottles for hide glue and I stumbled upon an item that may be of interest to some of you. Here is a link -
http://www.usplastic.com/catalog/product.asp?catalog%5Fname= USPlastic&category%5Fname=13721&product%5Fid=28027
It is a LDPE disc. I use these to line my radius dishes when gluing top and back braces. I used to use newspaper but often times the newspaper would stick to the back or top. These are translucent so you can easily center your plates on the dish. These work great and glue will not stick to them. I bought mine in rectangular sheet form from MSC and cut my own discs but these are a pretty good deal and thought I would pass it on.
tim...
PostPosted: Fri Dec 08, 2006 7:11 am
Thanks, Tim. LOTS of useful stuff there. If it's plastic, it looks like they've got it.
BTW, those discs are a clearance item, and they're really cheap--so get 'em now!
PostPosted: Fri Dec 08, 2006 8:45 am
I guess I don't understand? Line a radius dish? Huh? What for? Why? Me no understand....sorry if I'm dense...
PostPosted: Fri Dec 08, 2006 9:08 am
...so your braces don't stick to it when they are longer than the top/back.
PostPosted: Fri Dec 08, 2006 9:56 am
Just cut out a circle from a roll of 6 mil poly, price...free! They throw the stuff out by the arm loads at construction sites. If you are like me, you are always building stuff so you seem to always have a roll around. Also...your kitchen prbably has wax paper in it.....
PostPosted: Fri Dec 08, 2006 10:07 am
I use craft paper...StewMac gives it away free with every order I've never had it stick to the top or back.
But I really like the site reference...Thanks, Tim!
PostPosted: Fri Dec 08, 2006 1:58 pm
My dishes are made from particle board and ocassionally a nugget of hide glue gets dropped on the dish and it blends right in. No matter how careful I am sometimes I miss the nugget and then plop a top down (over news paper, wax paper, visqueen or the like) and I end up with a dent in a pristene top.
These LDPE discs have been a great help to me because the glue doesn't stick to them and it shows up on it so you can easily see it, they are thick enough that it masks any slight imperfections and the ocassional void in the dish.
Just thought I would share for those who may have an interest. Yep, lots of ways to skin a cat. This is just one that has proved beneficial to me.
tim...
PostPosted: Sat Dec 09, 2006 3:50 am
Hey Brother,
Thanks for the heads up. I just ordered 6 of each. I figured at these prices (85% off) I'll find many uses for them. Probably should have ordered more.
THANKS AGAIN!
PostPosted: Sat Dec 09, 2006 11:40 am
Thanks for the link Tim. I'm with Dave, I can see lots of other uses for these disks at this price.
PostPosted: Sun Dec 10, 2006 1:36 am
Speaking of other uses:
Cut smaller discs to place on top of a newly glued rosette then stack heavy weights on top of it to hold everything nice and tight while the glue dries.
Cut some small square or rectangles. Makes great squeegies for Z-poxy or spreading other adhesives.
Makes gread clamping caul liners for clamping headstock veneers.
tim...
PostPosted: Sun Dec 10, 2006 9:47 am
First name: Josh
Last Name: French
City: Houston
Maybe I'm dense too.... but why not just cut the excess off your braces before hand?
Instagram: @jfrenchluthier
