It is currently Sat Sep 13, 2025 9:57 am
PostPosted: Sat Nov 17, 2018 8:46 pm
First name: David
City: Napa
Zip/Postal Code: 94558
So I'm going to start using threaded. inserts and machine screws to bolt on my Fender style necks. Thinking bout 10-32 with 4 total. Why are you guys using for this application? Brass or aluminum inserts?
PostPosted: Sat Nov 17, 2018 9:30 pm
First name: David
Last Name: Schwab
City: Staten Island
Zip/Postal Code: 10201
I use 10-32 screws.
I use steel or brass inserts. This guitar has steel.
PostPosted: Sat Nov 17, 2018 10:29 pm
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
Rookie question...
When you say inserts are you talking about inserts that are anchored in the actual neck? And if so what is typically used to glue them in, or are they even glued?
PostPosted: Sat Nov 17, 2018 11:43 pm
Not aluminum. Prone to galling, and also prone to corrosion causing seizing.
These users thanked the author Chris Pile for the post: DavidSchwab (Mon Nov 19, 2018 10:40 am)
PostPosted: Mon Nov 19, 2018 12:31 am
First name: David
City: Napa
Conor. inserts that are anchored in the neck. The machine screws go through the body type with a grommet.
These users thanked the author dofthesea for the post: Conor_Searl (Mon Nov 19, 2018 12:35 am)
PostPosted: Mon Nov 19, 2018 9:09 am
First name: Roger
State: Oklahoma
deleted. Mis-read question.
PostPosted: Mon Nov 19, 2018 10:39 am
First name: David
Last Name: Schwab
City: Staten Island
Conor_Searl wrote:
Rookie question...
Yes. They aren’t glued in. The have sharp threads that screw into the hole.
https://www.rockler.com/steel-threaded- ... elect-size
These users thanked the author DavidSchwab for the post: Conor_Searl (Mon Nov 19, 2018 12:20 pm)
