It is currently Wed Aug 13, 2025 4:45 pm
PostPosted: Mon Jul 31, 2006 1:44 am
I just started level sanding an uke I sprayed with KMT-9 and sanded through in a couple of places. I pore filled it with Z-poxy which I don't think I sanded through but I'm not sure. This leaves me w/ three questions:
1) How can I tell if I sanded through the Z-poxy too?
2) What's the best way to spot fill these sand throughs?
3) How long should I wait to let the spot filled areas harden before continuing to level sand?
TIA,
Roy
PostPosted: Mon Jul 31, 2006 1:55 am
1. Is the color of the epoxy still there?
Most lilky just a wash of 60/40 zpoxy/alcohol in the sand through area will revive the color if you did go through. wait 24 hours seal that area with a thin wash of shellac.
2-3. After the wash of zpoxy/shellac as cured lightly rough up with 320p, lightly wipe with surrounding KTM9 with Denatured alcohol, allow to flash off and spray away 2-3 light coats. Let cure for a week and level and buff.MichaelP38929.4561111111
PostPosted: Mon Jul 31, 2006 2:14 am
Thnaks Micheal. I'll give it a shot this week sometime.
PostPosted: Tue Aug 01, 2006 4:12 am
Hi Roy,
could that uke be from the plans I sent you? I'm really interested to see/
hear it if it is. Actually, as everyone here loves pics, it'll be great to see it
even if it isn't from the plans.
Craig S.
PostPosted: Wed Aug 02, 2006 3:29 am
Hi Craig,
No, it's not from those plans. This is one I started ages ago and just can't seem to finish it up.
Hopefully, I will be doing a build from your plans later this year or early next year. I'll keep you posted.
