It is currently Tue May 06, 2025 1:19 am
PostPosted: Sun Aug 06, 2006 3:33 am
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
Have any of you built:
12 fret dred
00 deep body
What results compared to 14 body or 00 re: loudness, sound etc.
PostPosted: Sun Aug 06, 2006 5:08 am
How is the bracing different for a 12 vs 14 fret? Can you take a 14 fret plan and adapt it or is it completely different because of bridge placement? What is the scale length? Etc. Etc.
PostPosted: Sun Aug 06, 2006 5:15 am
You have to push the bracing around a little for the new bridge location. Don't push it to hard or it'll fall over.
PostPosted: Sun Aug 06, 2006 5:31 am
I've built one 12 fret Dred, and I think it was the best guitar I've built so far. I was going to keep it but a local bluegrass player takled me out of a couple of weeks ago and I sold it. I play fingerstyle and he is a killer flatpicker so it's probably in a better home.
Mine had a standard Dred scale, 25.4. The body is longer, 21", and the soundhole is moved a little lower. The upper bout is usually extended up to make up one fret difference, and the bridge is moverd back to make up the rest of the difference. I love the 12 fret shape, a lot curvier than a regular Dred.
The bracing has to change, but you have several options. With the bridge moved tword the tail you have to close up the X-brace angle a little or move the X-brace down so it still catches the wings of the bridge.   You can also make the bridge a little wider, or some combination of these options, or maybe something else I haven't thought of.
      Hope this helps, Paul Harrellpaul harrell38935.6073148148
PostPosted: Sun Aug 06, 2006 9:21 am
Lance needs to weigh in on this one. His slope-shouldered 12 fret dred was absolutely stunning!
I played and heard Lance's and it was loud, sustaining and very sweet in tone.
PostPosted: Sun Aug 06, 2006 10:52 am
I have built 3 deep body 00's, about 4 1/2 inches or more - awesome guitars. I use my own pattern, so doesnt make much sense to compare 12,13 or 14 fretters - the X shifts some in all of mine.
PostPosted: Sun Aug 06, 2006 1:51 pm
Last Name: Johnson
State: CO.
Has anyone built a Gibson AJ 12 fret?
Lance's is a Martin Slope 12 fret. Very worthy of consideration.
PostPosted: Mon Aug 07, 2006 3:23 am
Last Name: Johnson
State: CO.
Bump
PostPosted: Mon Aug 07, 2006 3:31 am
Last Name: Johnson
State: CO.
Thanks all
PostPosted: Mon Aug 07, 2006 8:15 am
Bump
i'm curious about this too!
PostPosted: Tue Aug 08, 2006 1:02 am
