It is currently Fri Aug 15, 2025 10:51 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
PostPosted: Tue Aug 15, 2006 8:00 am
[QUOTE=Brock Poling] [QUOTE=letseatpaste] Wasn't there a case made available for this shape from one of the custom case manufacturers? If revisions are ever made to the plan, this info might be useful printed on the plan (and you may get a kickback from the company).[/QUOTE]
Yeah, I think Ameritage makes one.
Also a very tight fit in an Access Stage 5 Small body if you cut 1/8" off of over all thickness of the plans. It will go at full 4 1/2" deep per the plans but it is very very tight, and you must remove both the removable heel pad and the removable lower back pad.
I am not sure if Ameritage is going to offer this as a std line case but they do have the specs and are building one for the OLF Build#2 project. If inquiring be sure to specify the OLF SJ Build#2 specs, because if you just spec an SJ you will get an Olson SJ.
Cedar Creek also has the specs but it was a custom build.MichaelP38944.7198842593
PostPosted: Tue Aug 15, 2006 8:22 am
This would be a good time to mention that John Hall/Blues Creek guitars stocks and sells bending and assemby forms. very top shelf!!!!
PostPosted: Tue Aug 15, 2006 9:21 am
I would like a set as well. Thanks homeys!
PostPosted: Tue Aug 15, 2006 10:17 am
I am interested in one set. Thanks.
Mark Routen
PostPosted: Tue Aug 15, 2006 11:46 am
Im in
PostPosted: Thu Aug 17, 2006 5:12 am
I think I would like one too please for a future project
Charlie
PostPosted: Thu Aug 17, 2006 5:45 am
Im going to let this thread run until tomorrow, at that time ill take a tally of what we need to order.
PostPosted: Thu Aug 17, 2006 5:51 am
I want to thank everyone here for making the library of plans and the SJ plans great success. I never would have dreamed the SJ would out sell the OM. Thanks again for your support of the forum through these plans.
Later this fall and I can't say just when yet, there will be a Gibson AJ (Advanced Jumbo)and my newly to be designed, MJ (Medium Jumbo-16"lb, 12"ub, 21"body, 4 5/8 major depth I think simular shape to the OLF SJ) I plan on working the design around a commonly available case so dims may vary a bit from posted.MichaelP38946.620775463
PostPosted: Thu Aug 17, 2006 1:18 pm
MichaelP, I am excited about the Gibson AJ plans, will Blues Creek be making molds and bending forms for this as well?
PostPosted: Thu Aug 17, 2006 1:35 pm
Lance,
I'd take a set.
