It is currently Wed May 07, 2025 4:48 pm
PostPosted: Fri Aug 18, 2006 1:00 am
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
What is the best adhesive to glue wood to metal and the item will be exposed fully to weather in Denver?
PostPosted: Fri Aug 18, 2006 1:16 am
I'm no expert (in anything) but I'd try gorilla glue.
PostPosted: Sat Aug 19, 2006 9:12 am
Screws.
PostPosted: Sat Aug 19, 2006 9:19 am
How about epoxy????
PostPosted: Sat Aug 19, 2006 9:26 am
Polyurathane is the answer (Gorilla glue for example). Epoxy will degrade with sunlight and heat. Poly is totally waterproof and uv proof. Though screws are indeed a good answer.
PostPosted: Sat Aug 19, 2006 9:45 am
I think they use West System Epoxy for making boats. That's one epoxy that should hold up to abuse...
PostPosted: Sat Aug 19, 2006 10:16 am
Alain, yes west systems is indeed used in boat building (I've done two myself with WS) but it has to be covered with UV varnish or it will degrade in no time flat.
PostPosted: Sat Aug 19, 2006 2:58 pm
Thanks Paul!
PostPosted: Sun Aug 20, 2006 1:01 am
Last Name: Johnson
State: CO.
Thanks for taking the time to post and thanks for the advise
