It is currently Mon May 12, 2025 1:27 am
PostPosted: Wed Aug 23, 2006 12:34 pm
Well after weeks of reading I finially finished my side bender. It is basically a Doolin inspired side bender with a few modifications. Last night grabbed a scrap piece of wood to give it a shot. During the first bend the wood cracked. I checked out a few posts and realized that my first test piece was on the thick side (about .150). Tonight I tried another test but this time I used a test piece that was .085 thick. It worked great! Well now it is time to finish my mold and start my first build of an SJ. Thanks again to everyone for sharing information.oOLF.
Brad
Avon, OH
PostPosted: Wed Aug 23, 2006 12:45 pm
Very professional looking! Good way to start!
Are you going to use a heat blanket?
awesome, are there plans available for this?
PostPosted: Wed Aug 23, 2006 1:04 pm
I like it! A lot!
I can't stand my Fox style bender. What a PITB that press screw is...
Can you give us some close-up shots of the details? I'd like to build one of those...
Thanks...
Don Williams38952.9207523148
PostPosted: Wed Aug 23, 2006 1:31 pm
[Quote=peterm]Are you going to use a heat blanket?[/QUOTE]
I am using a heat blanket with a router speed control to control the heat. I still need to come up with a good way to measure the temperature.
[Quote=molitovv]are there plans available for this?[/QUOTE]
At this point I am still very new to this and will need to prove out the design before I post any plans.
[Quote=don williams]Can you give us some close-up shots of the details?[/QUOTE]
I will post more pics tomorrow.
Brad
Avon, OH
PostPosted: Wed Aug 23, 2006 1:42 pm
First name: R
Last Name: Coates
City: Selma
[QUOTE=Brad Way] I am using a heat blanket with a router speed control to control the heat. I still need to come up with a good way to measure the temperature.
Candy thermometer. Wally world has 'em. They measure up to about 500 degrees. Just slide the probe in next to the blanket.
Nice bender!
PostPosted: Wed Aug 23, 2006 1:46 pm
Welcome to the forum, Brad.
Mine is similar to yours except yours is a lot more polished/professional looking. Good job.
PostPosted: Wed Aug 23, 2006 1:52 pm
[QUOTE=Hesh1956] Brad if you build that SJ half as nice as you built your bender you are going to have one great guitar! [/QUOTE]
I was thinking the same thing. Nice work, Brad!
PostPosted: Wed Aug 23, 2006 1:59 pm
Walmart also sells digiatl food thermometers for about $10 that work fine!
PostPosted: Wed Aug 23, 2006 2:26 pm
very nice bender,,, I built a similiar one except i used bolts in the side instead of the dowels, and i added the cutaway w/insert to my bod shape. If anyone wants to see some details of the Mike Dolin version,, just go to the top of the OLF page, look under the ON LINE RESOURCES section for the Mike Dolins side bender... I believe i have some pics i took along the way of the construction if anyone needs them. Since unlike most of you who actually build guitars, i still just build jigs and must get my thrills from that. It is also in one of the GAL issues, 48 maybe.. that and a few notes to Mike, who was very helpful, and I was all set..      Mike
PostPosted: Wed Aug 23, 2006 2:38 pm
Great looking bender Brad! You sure will have lots of fun bending this way, yours is really neat compared to mine also!
PostPosted: Wed Aug 23, 2006 3:35 pm
Brad, whats your sandwich composed of? Metal slats/blanket?
-jack handy
PostPosted: Wed Aug 23, 2006 8:27 pm
Welcome and well done, very slick look'in bender.
PostPosted: Wed Aug 23, 2006 10:19 pm
That's a great bender Brad !. I'll bet any money your first guitar will be fantastic .
Regards KiwiCraig
CRAIG LAWRENCE of AUSTRALIA
PostPosted: Wed Aug 23, 2006 11:37 pm
Very professional job. I think you are going to be super happy with that bender Brad.
PostPosted: Thu Aug 24, 2006 12:31 am
Nice looking bender Brad, I like the simple approach to benders and the more hands on technique they give, so that the reaction of the wood can be felt. The one modification I made to mine was to move the pivot for the upper and lower bout cauls to the centre of the 'arc' of the bout. This means that you can slide the caul round the bout giving it it's final tightening when the bout is bent, before finishing off the waist bend. Bit like this.
PostPosted: Thu Aug 24, 2006 12:56 am
Yes,That is a very nice bender Brad.
pro-looking. Welcome to the OLF,The friendliest forum you will ever find,IMO. Good luck with your first guitar.
PostPosted: Thu Aug 24, 2006 2:40 am
Ditto
PostPosted: Thu Aug 24, 2006 3:12 am
[QUOTE=Dickey] [QUOTE=Hesh1956] Brad if you build that SJ half as nice as you built your bender you are going to have one great guitar! [/QUOTE]
Ditto[/QUOTE]
That was my first thought too.
PostPosted: Thu Aug 24, 2006 1:09 pm
[Quote=Don Williams]Can you give us some close-up shots of the details?[/QUOTE]
I finished a few details tonight and attached a few close ups pics of the details. I am using a heater blanket and cut a small hole in the top spring steel sheet to allow the cord to stick through on the opposite ends of the springs. It seemed to get in the way when I had the other way around (with the cord on the spring side). As for the form itself..it was made from many sheets of MDF. A few of the sheets have cut outs in the middle that allow a few eye bolts to be run up through the form to bolt the form to the base. You can see the bolts sticking through the base on the previous pictures. This basically allows the whole things to be taken appart easily and the hardware used for different forms. As for the springs...they attached to the wood blocks and both slide over the steel extension rods. When everything is put together the steel rods slide through a two holes on the front of the base. At the bottom of the holes are a few rare earth magnets that hold the rods in. This allows springs to stay tensioned even with the front hold down clamp is not tighted. Well I am sure as I learn more I will continue to make improvements but so far I am pleased with the result. Now I just to get some wood and give it a shot. Thanks again for all the good feedback!
Brad
Avon, OH
PostPosted: Sun Aug 27, 2006 11:03 am
Man, you could sell those things! Excellent work and can't wait to see the guitar!!
PostPosted: Mon Aug 28, 2006 7:19 am
Those are all exceptional looking - I really need to get my but in gear and make one, although on my first build, Im going to use a male female mold for bending tasks. Wow guys good stuff!
I had to copy pictures, man my picture folder is getting huge and my custom screensaver is 70 Mb now,
Charliewood
PostPosted: Mon Aug 28, 2006 10:47 pm
Charlie, keep at it, it will come in time, soon enough, you'll have more jigs than pics!
Show some pics when you get a chance!
