It is currently Mon Aug 18, 2025 4:38 am
PostPosted: Sun Aug 27, 2006 2:45 pm
It is amazing how much difference .2 or even .1 millimeters can make! Take it down to .0825 (about 2.1 mm) and you'll see/hear/feel a world of difference.
Good luck.
-j.
-jack handy
PostPosted: Sun Aug 27, 2006 11:51 pm
I take it you are bending a venetian as well ?? I would go more like 70 thou there, more if its a tight one.
If this is a dry wood, ie loses moisture easy when bending, I would wrap in foil ( i always do anyway, I have blue spring steel which stains if I dont), forget the paper. The moisture cant really escape the foil, and the bend will be easier. In the fox, I am a bit slower then mentioned above, more like 1/2 to 3/4 turn every 30 seconds or so. Then go really slow with the spring caul on the upper bout - the lower never seems to be a problem, it can go much faster.
PostPosted: Mon Aug 28, 2006 2:05 am
First name: R
Last Name: Coates
City: Selma
Also are using a backing slat? I mean a piece of steel on top of the wood to give support. This wouldn't help with the waist cracks you show but it will with the cut away.
I will also second several motions made here;
Try HHG or even white glue for a more invisible repair.
Wrap your sides in tin foil it seems to help keep the moisture in.
Make em thinner. Much thinner at the cutaway.
Go slow.
I had similar trouble with bubinga sides and the above steps help me get the job done.
Good luck
PostPosted: Mon Aug 28, 2006 2:36 am
Thin the sides more, (.075" - .080") Don't use too much water as this will tend to weaken the crossgrain in the figure but do use the craft paper slightly wet. Use good heat 280°-300° and most of all, take your time and go slow. Are using spring support on the waist and cutaway? If not, I highly recommend it for figured wood.
PostPosted: Mon Aug 28, 2006 2:56 am
Thanks guys for all your input. I am using slats and next time will thin the wood a bit more.... The Zootman is sending me another set....don't think I'll be able to salvage this one!
live and learn....
PostPosted: Mon Aug 28, 2006 10:38 pm
Peter, i'd go with Tony's advice, 0.070" wrapped in foil and maybe some kraft paper inside the wrap as well if that woood loses it's humidity fast, just a thought!
Good luck with the cutaway bro!
