It is currently Sun May 11, 2025 10:01 am
PostPosted: Wed Aug 30, 2006 1:15 pm
I glued up a back with HHG and have a small gap at the bottom of the joint which is going to cause problems. How do I get the joint unglued? Thought about using a damp wash cloth and an iron to create the steam to loosen the joint. Any other or easier solutions?
PostPosted: Wed Aug 30, 2006 2:02 pm
First name: Alain
Last Name: Lambert
City: Trois-Rivieres
State: Quebec
Just saw (rip) in the joint.
PostPosted: Wed Aug 30, 2006 2:49 pm
A heat gun works well.
PostPosted: Wed Aug 30, 2006 9:25 pm
with hide glue you want moisture as well as heat.
if the plate is still rectangular and you have enough room, it is easiest to just rip it. if you have cut it to the rough shape moisture and heat will separate it.
PostPosted: Wed Aug 30, 2006 10:32 pm
An exacto knife heated on the hot pipe and a heat blanket to heat up the joint !Serge Poirier38960.3147916667
