It is currently Thu Aug 14, 2025 10:17 am
PostPosted: Thu Aug 31, 2006 3:58 am
Hi folks. I was looking around Breedlove's web page and thought this was quite interesting...
http://www.breedloveguitars.com/gallery/02/index.html
   I thought to myself... if there was enough tension on that truss, you would have a top w/no tension on it. Or at least a neutral balance. Does it make the bridge like a fixed point? Normal string tension in a sense gets the bridge close to a fixed point. Does the tension on the top itself contribute to vibration? Will it, being neutral, lose some acoustical advantages? Just maybe my mind wandering too much.
PostPosted: Fri Sep 01, 2006 5:30 am
Okay I'll say it - I think Breedloves sound like poo. There are folks that I
respect who really like them so there must be some desirable attributes to
thier tone, but they've never done much for me.
I still think of the "Bridge Doctor" as a last resort/quick fix for a cheap
guitar. I might stick one in a collapsing 12 string Giannini Craviola top, but I
wouldn't use them in a case where I was at all concerned with the guitar's
sound.
PostPosted: Fri Sep 01, 2006 8:17 am
First name: Hank
Last Name: Mauel
Zip/Postal Code: 95603
[QUOTE=ToddStock] I think neutral tension is a bit misleading...the compressive load on the soundboard from string pull is certainly still there, as is the download from the saddle, so as far as I can see, only the torsional load is reacted by the Bridge Doctor.   The system should still allow brace and top thickness reduction; however, at least on the Breedloves I've seen, the tops and braces looked about as heavy as more conventionally constructed instruments in the same price range.[/QUOTE]
If you are REALLY BRAVE, remove the Bridge Dr. and see what the top of the Breedlove does!
Hank Mauel
PostPosted: Fri Sep 01, 2006 9:20 am
Played two Breedloves with the JDL system.... didn't anything for me...on the contrary!
