It is currently Fri Aug 15, 2025 1:09 pm
PostPosted: Sat Sep 16, 2006 3:24 pm
On a 14 fret neck, how far from the nut are you guys installing your truss rods?
PostPosted: Sat Sep 16, 2006 3:45 pm
Ron,
I put my adjustment through the sound hole and the end of the truss rod slot stops .25 from the end of the finger board, if thats what you asking. I may have it completely sdrawkcab however.
PostPosted: Sat Sep 16, 2006 10:55 pm
Mine end up about 5/8", but for me that's really dictated by the length of the truss rod since I am buying them prebuilt. It varies a little with the scale length.
David White, Toronto
PostPosted: Sun Sep 17, 2006 12:32 am
That's what I wanted to know, thanks. Mine adjusts through the sound hole also, it's a 14 1/2" two way rod, and I'm starting my groove about 1/2" from the nut. I guess I'm good to go. Appreciate it.
PostPosted: Sun Sep 17, 2006 12:52 am
1/2" to 1" from nut on my steel strings.
PostPosted: Sun Sep 17, 2006 3:45 am
Ron, same as you, 1/2".Serge Poirier38977.5322106481
cron
