It is currently Mon May 12, 2025 6:46 pm
PostPosted: Sun Sep 24, 2006 9:20 am
What are some of the ways that some of you have "fixed" or filled in small (1-3mm) holes in your tonewood?
I've heard m.o.p. dots being used, but I'm not sure I can picture that.
Do you fill them to match? Fill them to contrast? Pics would be appreciated.
-j.
-jack handy
PostPosted: Sun Sep 24, 2006 10:37 am
   It depends on the woods. I like to inlay a small piece that is irregular shape so it fools the eye. A little touch up and you can make them invisible.
   Amacing what you can do with some art colors and such.
PostPosted: Sun Sep 24, 2006 11:08 am
I like to fill them with black epoxy.
PostPosted: Sun Sep 24, 2006 12:09 pm
Last Name: Lewis
City: Newnan
State: Georgia
Zip/Postal Code: 30265
Try this page on Allied lutherie's site for instructions on fixing wormholes, if you haven't seen it.
Good luck-
John Lewis
PostPosted: Sun Sep 24, 2006 2:12 pm
I have a bookmatched pair of wormholes on the back I'm building now, about 2mm diameter. That's character!! They stay untouched.
PostPosted: Sun Sep 24, 2006 4:07 pm
[QUOTE=old man] I have a bookmatched pair of wormholes on the back I'm building now, about 2mm diameter. That's character!! They stay untouched.
Ron[/QUOTE]
And besides, they'll make small soundports for free for that customer!
PostPosted: Mon Sep 25, 2006 12:59 am
I build alot of BRW classicals and almost always have to deal with holes. On a dark wood when you mix sanding dust with a glue/binder (epoxy, CA, etc) it blends in well and under a finish will disappear unless you are looking for it.
Contrasts are another way to go but only if you want to emphasize and that usually comes down to a matter of placement and amount of holes.
PostPosted: Mon Sep 25, 2006 1:14 pm
[QUOTE=Serge Poirier] [QUOTE=old man] I have a bookmatched pair of wormholes on the back I'm building now, about 2mm diameter. That's character!! They stay untouched.
Ron[/QUOTE]
And besides, they'll make small soundports for free for that customer! [/QUOTE]
Or drain holes so I can play in the rain.
PostPosted: Mon Sep 25, 2006 1:35 pm
playing fluid songs!
PostPosted: Tue Sep 26, 2006 1:28 am
I won't discuss the time that I accidentally drilled a hole in the side of one of my guitars.
PostPosted: Tue Sep 26, 2006 3:05 am
Go ahead Al!
PostPosted: Tue Sep 26, 2006 4:07 am
Enhance it. I have a set of H. Mahogany sides that each have a worm hole. No way to fill that w/o it showing, so I have a design to inlay a worm crawling out of one hole and the back end of the worm going in the other hole. Haven't implemented this yet, still on the drawing board.
Alan D.
