It is currently Mon Aug 18, 2025 9:51 am
PostPosted: Tue Sep 26, 2006 7:33 am
If you aren't French Polishing, but using a different type of finish i.e. KTM9, Nitro, Target USL...do you use a seal coat of shellac before your final finish?
PostPosted: Tue Sep 26, 2006 7:39 am
Yes. Some have said they have had issues with KTM9 directly over Zpoxy or other epoxies. Others say they have had not problems at all. I always seal with a 1# cut of shellac before spraying nitro or KTM9
use a seal coat of thinned epoxy about 50% DA or better yet grain alcohol like everclear, wiped on thin.John How38986.6947337963
PostPosted: Tue Sep 26, 2006 7:57 am
I had issues with KTM-9 over shellac, but I think it was because I didn't sand the shellac. It was too slick a surface for the KTM-9 to grab hold of. It needs a good mechanical bond. I've tried it with shellac that was sanded, no problems.
PostPosted: Tue Sep 26, 2006 8:32 am
I use McFadden's nitro, and I use their vinyl sealer on top of pore fill, but not
shellac. However, I tend to sand back the epoxy so it remains only in the
pores; I don't like the color or texture of epoxy on top of the wood grain. It's
a bit tedious, because it's easy to overdo it and remove the epoxy in the
pores, but it's worth the effort for me. crazytooguy38986.7308564815
PostPosted: Tue Sep 26, 2006 12:09 pm
i have only one experience,, KTM9 over system 3 epoxy on maple.. Didn't need to pore fill, but liked the tone the epoxy gave to the maple. The KTM9 was cold and very clear. No trouble with adhesion.
PostPosted: Tue Sep 26, 2006 12:16 pm
Like the crazytooguy above I've been spraying McFaddens and use their vinyl sealer over the epoxy. I've had no adhesion problems . I've used various brands of epoxy for pore filling and recently tried the Zpoxy stuff from LMI and like very much as it sands really well.
PostPosted: Tue Sep 26, 2006 4:22 pm
First name: R
Last Name: Coates
City: Selma
Same here. I've used Oxford PSL and more recently KTM-9 over System 3 epoxy with no problems. The oldest one of mine is about two years old and no worries so far.
