It is currently Fri Aug 15, 2025 2:24 am
PostPosted: Sun Oct 15, 2006 4:01 am
Hi everyone
The chuck on my dremels has been seized on by rust. I've tried to break
the hold with vise grips, but the plastic housing around the collar pulls
apart before the chuck gives any indication of giving up. I sprayed some
liquid wrench in there to no avail. What should I do? Are there other
ways to get it to release, or do I need a new dremel? There are only two
operations I need to use it for, so I'd prefer the cheaper solution.
PostPosted: Sun Oct 15, 2006 4:04 am
maybe try a little heat as well to swell up the parts,
hope this helps, Evan
PostPosted: Sun Oct 15, 2006 4:07 am
You're on the right track with liquid wrench. Spray it, and let it sit for 2-3 hours spray again, let it sit again etc. It may break free after several tries apply a little heat with a soldering iron-not too much, and watch for fumes from the liquid wrench. If all fails, then it's time for a new tool.
PostPosted: Sun Oct 15, 2006 4:12 am
Try a sharp "hit" on the end of the collet with a hammer, before taking the wrench to it again. That will sometimes shock the threads and allow them to release.
Otherwise, open up the body, find a way to hold it, and use a real wrench on the collet
PostPosted: Sun Oct 15, 2006 4:15 am
i suggest the heat, heat only the outside of the collet, it should expand and come loose, not too hot though, or you will anneal the metal. stop heating before it changes colour.
good luck
PostPosted: Sun Oct 15, 2006 5:24 am
BTW , on my model, there is a plastic/rubber transmission sleeve attached to the business end, inside the case. If this is your case, avoid the heat!
PostPosted: Sun Oct 15, 2006 7:06 am
Great. Thanks a bunch, guys. I'll try these things and report back.
PostPosted: Mon Oct 16, 2006 1:06 pm
I tried the hammer tip before and it worked right away.
PostPosted: Mon Oct 16, 2006 1:48 pm
Liquided, heated, and hammered. I had to go get a replacement. Haha,
oh well. I don't know how it even happened. This thing's seized on like
me to a corn dog.
