It is currently Fri Aug 15, 2025 7:45 am
PostPosted: Thu Oct 19, 2006 12:16 am
BRACE LOCATIONS FROM THE NECK EDGE TO THE FRONT OF THE BRACES
1ST BRACE 3.750
2ND        7.250
3RD       10.750
4TH        14.500
PostPosted: Thu Oct 19, 2006 12:32 am
Thanks John!
So, from the inside edge of the guitar side? NOT from the front of the neck block>?
PostPosted: Thu Oct 19, 2006 12:49 am
Not much diff from what I use on every guitar - from the neck/body joint, 4, 7.25, 10.75, 14.75.
PostPosted: Thu Oct 19, 2006 4:01 am
   This is from the "Front" of the guitar. If you are off the thickness of the side set that isn't going to make any difference.
The spec of the bracing is
ols style
# 1 & 2 .250 by .625
# 3 $ 5 .750 by .250 ( rounded like a broom handle )
New style
1 & 2 same
3 $ 4 .380 by .750
both at a 20 foot radius
   There ya go
john
PostPosted: Thu Oct 19, 2006 4:07 am
Thanks John!
PostPosted: Thu Oct 19, 2006 5:14 am
you are all welcome
PostPosted: Thu Oct 19, 2006 6:00 am
John thank you very much! I really appreciate the info.
Lance good luck with your "O". What will you be using for the back/top of yours?
I've got some really nice quilted maple and a Sitka top for mine and will probably use birdseye or curly maple for the neck.
PostPosted: Thu Oct 19, 2006 10:09 am
Last Name: Lewis
City: Newnan
State: Georgia
Zip/Postal Code: 30265
Thanks John! It's nice to have this along with the body and side templates.John Lewis39009.7991550926
John Lewis
