It is currently Fri Aug 15, 2025 9:51 am
PostPosted: Thu Oct 26, 2006 5:26 am
Hi Folks,
I am in need of some Koa Purflings.
Preferably with a .010 black fiber strip on each side, so it would be b/koa/b but I could work with out it.
Anyone out there got this? If so what thickness?
Thanks!
PostPosted: Thu Oct 26, 2006 5:37 am
How thick are the purfs, will they be wide enough to tell they are Koa?
PostPosted: Thu Oct 26, 2006 5:41 am
preferably around 028”, so I suspect you'll be able to tell?
PostPosted: Thu Oct 26, 2006 5:50 am
Lance, I have some Koa purfs, I think they are .024 but I am not near them right now to tell. I black fibre lines also. Just need to see if I have .010. I know that I do have .020.
I will in a while and let you know.
PostPosted: Thu Oct 26, 2006 6:06 am
Thanks Shane!
PostPosted: Thu Oct 26, 2006 8:10 am
Lance,
The Koa is indeed .024. The only black fibre I have right now are .030 in the purf dimensions and then I have .020 double length purfs by .250 wide so you would have to trim them with a knife but you could get double lenght purfs three per strip. I do have some EIR purfs that are a dark purple. They are about .022.
If any of this helps you can just PM me with your wishes.
Thanks lance
PostPosted: Thu Oct 26, 2006 8:26 am
Hey Lance, I used Shane's purflings in my rosette. I used the .02 black
double length and the koa.
