It is currently Sun Aug 17, 2025 10:35 pm
PostPosted: Mon Nov 27, 2006 1:11 am
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
I have seen responses here that indicate that those that use 1/4" saddles believe that extra width makes better for intonation. True? If so., why don't more members use the thicker saddle?
PostPosted: Mon Nov 27, 2006 1:15 am
Good question Bob, i used a thinner one on no 2 but noticed that Hesh and Alain use thicker ones that seem to help, i am curious on this matter too so i'll bump to hear more!
PostPosted: Mon Nov 27, 2006 1:19 am
Probably because of tradition. Also, some don't like the look of a wide
saddle. Personally if you place your saddle slot correctly you should be
able to intonate with as narrow as 3/32 but it is a lot easlier with a wider
one. I am switching to 3/16ths.    With a wider one, you also can have a
more gentile slope on the tail side of the saddle which allow for better
contact and you are less likely to break strings. Also, if you change string
types etc you have more flexibility to adjust it.
1/4 is a pretty thick. I think Brock is using that width. Hopefully he will
chime in.
I asked this question in a poll recently and 1/8th was clearly the most
common. I asked Ervin Somogyi and Mike Doolin since I respect them
highly and they both use 3/16th
PostPosted: Mon Nov 27, 2006 1:24 am
Thanks Andy, makes sense to me to use a wider saddle also, the question remaining is how wide is too wide for aesthetics, i'm guessing that 3/16" would look right too!
PostPosted: Mon Nov 27, 2006 1:33 am
Mine are 3.5mm and have been plenty wide enough for me. If I had trouble with intonation, using one that wide, I'd probably go to the split saddle like my compatriot Dave White uses.
PostPosted: Mon Nov 27, 2006 1:36 am
It isn't about intonation, it is about how the string makes contact with the saddle.
Ervin Somogyi wrote an indepth article about it in an old AL or Guitarmaker journal. It is pretty convincing.
I will see if I can dig up what mag and issue it was.
PostPosted: Mon Nov 27, 2006 4:20 am
Thanks Brock!
PostPosted: Mon Nov 27, 2006 5:39 am
First name: Coe
Last Name: Franklin
City: Decatur
IIRC, Frank Ford`s site has some pretty good info.
I can`t seem to find the link at the moment, though.
