It is currently Sat Jul 26, 2025 1:11 am
PostPosted: Mon Apr 18, 2005 8:00 am
Lance, here are some images of a neck block I did today. Because I use the crazy spanish foot thing, I have to make a compound angle on the neck block as well. When done everything sits up tight and it all looks really smooth.
Pwoolson38460.7093055556
PostPosted: Mon Apr 18, 2005 8:42 am
Do you cut that by hand?
PostPosted: Mon Apr 18, 2005 9:41 am
Yep, everything but the "W" which I had laser cut into the block.
PostPosted: Mon Apr 18, 2005 12:06 pm
Wow Paul, mighty nice joinery there!
PostPosted: Mon Apr 18, 2005 2:26 pm
Paul,
Very impressive looking. Love the lazer cut W.
What do you use to cover the face of the block where the bolt are?
Jeff
PostPosted: Tue Apr 19, 2005 12:05 am
I haven't been covering the bolt heads. I can't come up with a good way to do it and still give me the access I need. I think the counter sunk holes at least make the bolt heads look "intentional".
PostPosted: Tue Apr 19, 2005 12:08 am
Thank you Paul - that really clears it up - a picture is worth
PostPosted: Tue Apr 19, 2005 12:22 am
Lance, I assume you don't use the foot like mine. With that in mind you still might think about making the block angle in both directions. One for the shape of the neck, the other so the cutaway flows into it nicely. If you leave it squared off 1) there isn't much surface to glue the cutaway to and 2) It looks like there is a huge gap between the block and side.
You can just eyeball the angle at which the cutaway comes into the block. The precise angle isn't really that important, if you get it close, it will look better than if you leave it squared off.
PostPosted: Tue Apr 19, 2005 2:00 am
First name: Harald
Last Name: Lane
City: Vienna
Country: Austria
Nice work Paul! I?ve used a block copied from C.Fox on my Cutaway OM. Unfortunatly I have no photo, one difference to your system, my Cutaway follows a curve at the block, not a straight line. I was difficult to get the correct radius on top and back, also I used epoxy to glue the sides to the block, just to be sure if there is a slight gap between them.
http://www.hl-guitars.at
