It is currently Sun Aug 17, 2025 8:38 pm
PostPosted: Tue Nov 28, 2006 1:43 pm
I was able to get quite a bit done again today.
I finished installing and scraping my binding flush (still have some minute
gaps in the purfling between the ebony and maple-any tips?)
The body is sanded and once I get the gaps in the purfling figured out
she'll be ready for vinyl.
The fretboard slots were drilled, taper cut, radius sanded, finish sanded
and buffed.
I also glued up my heel block, routed the channel for truss rod and
installed it. Next week is neck shaping time and final squaring away of
the box!
Christopher C. Cordle
North Muskegon, MI
PostPosted: Tue Nov 28, 2006 1:47 pm
Great job Chris, moving along nicely....did you get the inlay bit info I posted for you?
Greg
Gwaltney Guitars
PostPosted: Tue Nov 28, 2006 1:48 pm
Looks great Chris. Hard to believe it is your first!
Brad
Avon, OH
PostPosted: Tue Nov 28, 2006 1:54 pm
[QUOTE=GregG] Great job Chris, moving along nicely....did you get the
Greg[/QUOTE]
Thanks Greg,
Yes, I did get the info. I'd love to see it in action as I'm still not getting the
entire picture. I understand the concept but not how it plays out.
Does the bearing ride inside your template? Just wondering how you're
able to get the nice tight corners as it seems the bearing would keep you
out of the corner. I know that I'm not seeing this clearly in my mind but
do appreciate your patience with this newbie.
North Muskegon, MI
PostPosted: Tue Nov 28, 2006 2:00 pm
[QUOTE=Hesh1956] Chris this is your first guitar?? Wow!! I am
impressed!
Your work looks excellent, very neat and clean building.
What is the fretboard BRW? It's a beautiful piece and will be a real
attention getter I am sure.
To fix the gaps I just squeegy some Titebond or LMI white glue in the gap
and then sand the area in the diection of the gap to get some dust
mashed in there. Some folks use CA just be sure to seal the top in that
area with shelac first so that it does not stain.
I use about 1/3 more tape when binding too and really pull it as tight as I
can get it and this eliminates gaps as well. In areas that are difficult like
the waist I double the tape on top of tap so that I can really pull it tight
with out tearing it.
Beautiful work!!!![/QUOTE]
Yes Hesh, this is my first and thank you.
The fretboard is just un-dyed ebony. My instructor has stacks of these
from the old Gibson shop.
Your gap tip sounds like it would work fine but I don't understand the
meaning of the "direction of the gap".
Thanks again Hesh. Will you be at the MI guild meeting on Saturday?
I'm hoping to go if possible.
North Muskegon, MI
PostPosted: Tue Nov 28, 2006 2:09 pm
Yes, the bearing rides on the inside portion of the jig/pattern. Remember you are only cutting the inlay & the cutout in the guitar on the sides/edges, there are no turns or inside corners being used, you will cut the inlay off(top and bottom)after the sides/edges are cut in the jig and removed. I know this is difficult to envision, I'll try to take some pics for you this weekend.
Greg
Gwaltney Guitars
PostPosted: Tue Nov 28, 2006 2:12 pm
Chris, that is some very cool ebony. You say you can get some more....any matching bridges and head stock plates???? Who needs inlay when you have wood like that.
Very well done, it looks great. Can't wait to see more of the neck process and completion soon afterward.
PostPosted: Tue Nov 28, 2006 2:23 pm
That is one gorgeous guitar.
AND
That is the coolest looking fretboard I have ever seen.
As far a fiilling the gaps, I use superglue
If wide, I use a bit of dust from the back.
If on the top, a sliver of top wood
No inlay needed on that fretboard. It is just stunning!!!!
PostPosted: Tue Nov 28, 2006 2:42 pm
You work well under pressure, Chris!    It's gonna be mighty pretty!
P.S. It looks like you know exactly what you're doing. How'd you do that?!!!
PostPosted: Tue Nov 28, 2006 3:24 pm
I've never seen a FB like that either. Is it macassar ebony? Reminds me of the flames painted on an old '32 roadster. Neato.
PostPosted: Tue Nov 28, 2006 3:44 pm
Ron, you remember 1932, your older than I thought    (what a smart a#*)
PostPosted: Tue Nov 28, 2006 6:07 pm
Great Job for a first!! Are you keeping the fretboard that way? very cool!!
PostPosted: Tue Nov 28, 2006 7:38 pm
i keep scrolling back up to that fingerboard photo.....just stunning...can't wait to see the finished guitar
PostPosted: Tue Nov 28, 2006 8:25 pm
Chris, fantastic looking instrument! Be it a first of hundreth!
Vinyl? Are you spraying that yourself? That's the way I'm eventually hoping to go too...
Keep up the great work!
PostPosted: Tue Nov 28, 2006 11:31 pm
That guitar looks awesome already and she's just your first?! Not even completed yet and WOW! Great job Chris!
PostPosted: Wed Nov 29, 2006 12:03 am
[QUOTE=old man] I've never seen a FB like that either. Is it macassar
Ron[/QUOTE]
The fretboard is just un-dyed ebony from the old Gibson plant.
I went through a stack of these before I found this one.
North Muskegon, MI
PostPosted: Wed Nov 29, 2006 12:05 am
[QUOTE=peterm] Great Job for a first!! Are you keeping the fretboard that
way? very cool!![/QUOTE]
Peter,
Yes I am keeping the fretboard that way. What else would I do with it?
Well, maybe add some frets!
North Muskegon, MI
PostPosted: Wed Nov 29, 2006 12:07 am
[QUOTE=Alain Desforges] Chris, fantastic looking instrument! Be it a
first of hundreth!
hoping to go too...
Alain,
I'm not sure if I'll be spraying the vinyl or just observing.
Knowing my instructor I have a feeling he'll tell me how to do it and turn
me loose.
North Muskegon, MI
PostPosted: Wed Nov 29, 2006 12:10 am
[QUOTE=Serge Poirier] That guitar looks awesome already and she's just
Great job Chris![/QUOTE]
Yes, she is a first and I do appreciate all the nice comments.
I must confess this is a 1 foot guitar....which is to say she looks excellent
from a foot away! There are mistakes I made that would be very evident
to a luthiers eye but maybe not to the common person.
North Muskegon, MI
