It is currently Tue Aug 19, 2025 3:10 am
PostPosted: Sat Dec 09, 2006 3:52 pm
Hello all. I'm planing my first Baritone and I was wondering about the scale length.
I've started drawing out at 28.5 and also 30.0. Being a person of extremes, I thought I would like and extremelly long scaled baritone but now I find that the 28.5 looks more balanced and probably would play a lot better than the 30 inch one...
I'm joining at the 15th fret.
Any thoughts or suggestions are more than welcomed.
Thanks in advance.
PostPosted: Sat Dec 09, 2006 4:44 pm
Alain, here is a thread regarding Baritone's and near the bottom Tracy has a link to David Berkowitz's website where there is a good article on baritone guitars.
Hope this helps.
PostPosted: Sat Dec 09, 2006 5:18 pm
Right on Rod! Great threads and related articles...
I'm toying with the 14-15 fret question. I'm also trying not to push the soundhole and bridge too far towards the tail. Plus, it has to fit in a regular case...
I'm leaning towards 29 inch joined at the 14th... Should have a good .25 inches spare to fit in a case...
PostPosted: Sat Dec 09, 2006 6:54 pm
First name: Louis
Last Name: Freilicher
City: Belchertown
State: MA
Zip/Postal Code: 01007
I played a very nice baritone recently that had a 28" scale. It was built on a
martin 12-fret D body with the neck joining at the 14th fret. I believe most
of the bracing worked out fine.
Louis
- Louis Freilicher
PostPosted: Sat Dec 09, 2006 7:40 pm
Thanks Louis.
I drew on tonight with a 29inch scale joined at the 14th. Everything looks fine and it should fit in a regular case with no problems...
PostPosted: Sun Dec 10, 2006 2:35 am
Having built both 28 and 29 inch scales, I have to say that the 29 didnt realy add much to the tone. I thought it would help out with and A-A tuning over the previously built 28, but it really didnt. I think I am settling on 28 to 28.5 somewhere as the norm for mine, keeps the finger stretches down a touch as well. And as well, whether its my trad jumbo, or new Solo shape, 14 fretters, they both will fit fine into a TKL 9120 case - thats a bonus.
PostPosted: Sun Dec 10, 2006 2:39 am
Oh, and as its mentioned I think on the Berkowitz site, the softer woods like walnut, mahog and koa tend to work better. I built one from EI rw, it worked well, but I liked the tone of the mahogany better.
PostPosted: Sun Dec 10, 2006 1:28 pm
Right on Tony, I was hoping you'd weigh in on this thread... I was talking to Anthony the other day and he mentioned that you had quite a few Baritone's under you belt...
I was thinking of using Wenge for mine. I have plenty of it on hand. If it doesn't turn out that fantastic, it's no biggy. I also have some very nice flamed maple, but this I'd have to re-saw.
Interesting about the 29 vs. 28... I might bring it down to 28.5, as you said, no perceived gain in tone from A-A and it'll be easier to graple with...
Thanks Tony!
PostPosted: Sun Dec 10, 2006 8:07 pm
I am building a 28 5/8" right now. We'll have to compare notes.
-j.
-jack handy
PostPosted: Sun Dec 10, 2006 9:14 pm
J., sounds like a plan!
PostPosted: Sun Dec 10, 2006 11:28 pm
Looks like you're well on your way to make another fine Desforges my brother, can't wait tho see this one developing on your bench!
PostPosted: Mon Dec 11, 2006 12:50 am
Personally I would save the wenge for something else .. get a plain set of walnut, its pretty cheap, you wont be disappointed.
PostPosted: Mon Dec 11, 2006 9:09 am
First name: Hank
Last Name: Mauel
Zip/Postal Code: 95603
Try contacting Lance McCollum. I think he's using a 27.5" scale and his baritones sound awesome.
Check in the Memebers List for contact info.Hank Mauel39062.7154976852
Hank Mauel
