It is currently Tue Aug 19, 2025 5:44 am
PostPosted: Sat Dec 09, 2006 10:00 pm
I came across THIS POST at the Sawmill Creek Forum, don't know how accurate the chart is but it may give some insight for anyone needing to buy a new blade.
PostPosted: Sun Dec 10, 2006 12:54 am
For years, Mario has touted the 40 tooth Freud Diablo 7-1/4" Finish Blade. Of note is that it produces a thin kerf (.053"). I finally bought one which replaced a larger general purpose Freud blade and was astounded at it's performance. And here's the bonus...they cost less than $20 each. For the stuff we do in guitar work, this is an ideal blade!
PostPosted: Sun Dec 10, 2006 1:02 am
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
Larkim,
Thanks to you and others who find new cites and forums!
PostPosted: Sun Dec 10, 2006 12:30 pm
Can anyone recommend the 80 tooth 10" Freud Diablo blade? I went into HD today to pick up a 7-1/4" Diablo, and I saw they had a special good through Jan 3 (I think) where if you buy a 10" or 12" 80T blade ($50), they'll send you a 7-1/4" 40T for free.
PostPosted: Sun Dec 10, 2006 1:40 pm
Your most welcome Bob, hope you find it useful.
PostPosted: Sun Dec 10, 2006 2:01 pm
Jon, check out freud's website on their diablo blades. You'll get the best ideas there.
That's a great deal for HD, I'd take that one up if I were you.
PostPosted: Sun Dec 10, 2006 2:14 pm
Thanks, Rod, I think I may take them up on that deal the next time I'm there. Looks like the 80T 10" would do the trick for a scarf joint table saw jig.
PostPosted: Sun Dec 10, 2006 2:24 pm
Don't forget about the cut's that you want to do with this blade (the 10" that is), 80T is a very fine finishing blade, you don't want to be ripping lumber with this one (sorry if this is something you already know, don't want to assume though). Will it be a general, all purpose blade, finishing blade, ripping blade, cross cut. See what your options at HD are and then get the one that would compliment your saw blade quiver.Rod True39061.9351157407
PostPosted: Sun Dec 10, 2006 4:37 pm
Right, I was thinking of this for crosscutting situations where I was going for a fine "glue-ready" cut like a scarf joint.
PostPosted: Sun Dec 10, 2006 7:40 pm
Last Name: Abercrombie
I'll second Rod's caution about the 80T blade. Unless you are working with thin stock, even a partial rip cut (scarf) will tend to fill the small gullets on this blade with sawdust/shavings and leave you with the possibility of glazing (or even burning) on the cut surface. This can result in a smooth-looking cut that makes a terrible glue bond.
PostPosted: Mon Dec 11, 2006 12:22 am
[QUOTE=ToddStock] It's worth mentioning that the Ridgid brand (Home Depot) blades are made by Freud, and they did well in the last magazine ratings.
The magazine reviews are useful, but the blade I see used most often in cabinet shops is a Forrest.
I've been told that Ridgid made Craftsman product up untill a few years a go. Not sure if thats the case or not.
PostPosted: Mon Dec 11, 2006 12:23 am
I'll have to see if HD was offering the deal with any other blades. I think maybe it was only for the 80T 10" and 12" blades, so it may not be such a deal if it's a blade I won't end up using very much.
PostPosted: Mon Dec 11, 2006 12:26 am
I bought the 80T Diable 10" last week from HD. I had planed on using it for my scarf joint but it sounds like that mayhave been a mistake.
PostPosted: Mon Dec 11, 2006 3:23 am
[QUOTE=JJ Donohue] For years, Mario has touted the 40 tooth Freud Diablo 7-1/4" Finish Blade. Of note is that it produces a thin kerf (.053"). I finally bought one which replaced a larger general purpose Freud blade and was astounded at it's performance. And here's the bonus...they cost less than $20 each. For the stuff we do in guitar work, this is an ideal blade! [/QUOTE]
He runs this on a 10" saw? If so why not run a 10" blade?
PostPosted: Mon Dec 11, 2006 3:48 am
A smaller blade is going to be more stiff than a larger diameter blade. Also cheaper...
PostPosted: Mon Dec 11, 2006 4:12 am
Good point
