It is currently Tue Aug 19, 2025 9:20 am
PostPosted: Thu Dec 14, 2006 1:42 am
State: ON
I use a straight 16 on my 6-strings. What do you guys use on your 12-strings? Is there a standard radius that factories use?
joshJosh H39065.4101273148
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Thu Dec 14, 2006 1:57 am
I have used 20 and 16 both
PostPosted: Thu Dec 14, 2006 1:59 am
12 to 20 compound. which makes 16 at the 12th fret. They've played very well. Pwoolson39065.4169675926
PostPosted: Thu Dec 14, 2006 9:59 am
State: ON
Thanks guys,
I only have a 16 radius block so I will probably give that a try. I'm curious to know what the factories are using. I will have to do a little more research.
Josh House
PostPosted: Thu Dec 14, 2006 10:42 am
Josh, i think 16" is the most common even for 12 strings...
PostPosted: Thu Dec 14, 2006 11:12 pm
Hi Josh,
           I'm building a twelve as well. I've decided on 20" because of the neck width .
Regards Craig
CRAIG LAWRENCE of AUSTRALIA
PostPosted: Fri Dec 15, 2006 1:49 am
I just checked a Martin J21-16 it is 16" radius
PostPosted: Fri Dec 15, 2006 3:15 am
martin guild and taylor all use 16" on current offerings.
many older martins were compound 16-20"ish. i have also seen a few old 12's with a flat board. barre chords were not being played much on 12's then i guess.
