It is currently Tue Aug 19, 2025 10:18 am
PostPosted: Mon Jan 08, 2007 12:05 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
So if a person is going to make a slotted head for a steel string and use tuners such as Grover 18:1.The specs are .6875 plate thickness,which is thicker than a steel head.So is a person making a classical headstock thickness for steel string?I`ve got cumpiano`s book which has dimensions for classical.Also do I drill a 10 MM hole for those?
                        Thanks James
I`ve been posting a lot lately.I`m getting tired of being a walnut.Almost time for the big game.
James W Bolan
Nashville Tennessee
PostPosted: Mon Jan 08, 2007 12:31 pm
I make my slotheads 3/4" thick and drill according to whatever tuners are going to be used.
PostPosted: Mon Jan 08, 2007 1:09 pm
First name: Danny
Last Name: Vincent
My slot head National has a 13/16th headstock and having drilled my first
classical head today, the tuner holes were 10mm. Yours will be smaller. I
used a jig that had three holes drilled in it. If you made one out of
hardwood it would probably be faster overall and you can be sure the
spacing is right by putting your tuners into the jig. Make the jig the same
thikness as your head and clamp it on with a couple of strips of wood.
Works slick.
Cheers, Danny
PostPosted: Mon Jan 08, 2007 3:14 pm
And drill for the tuner posts before you cut the slots. Wish I could remember that.
PostPosted: Mon Jan 08, 2007 3:53 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Who is MSC?
                James
James W Bolan
Nashville Tennessee
PostPosted: Mon Jan 08, 2007 5:37 pm
[QUOTE=James W B] Who is MSC?
                   James [/QUOTE]
James,
Look at mscdirect.com
Industrial supply. You could spend days browsing (or thou$ands)
PostPosted: Tue Jan 09, 2007 12:31 am
I make mine 3/4 - the Luthier tools slot head jig expects that to centre the tuner holes on the sides. BTW, that thing is priceless .. it makes slotheads dead easyt o do. I did make antoher jig to hold that jig vertical on the drill press though, to drill the tuner holes .. I did a test by hand and they came out a little rough, hard to control the pull of the drill bit. Works like a charm now though. Amd like Howard says, drill first , route last !!!
PostPosted: Tue Jan 09, 2007 4:30 am
Howard,
Thanks for the reminder to drill first. Another blunder averted...thanks OLF!
regards,
Tom Armstrong
PostPosted: Tue Jan 09, 2007 10:59 am
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Thanks guys
                       James
James W Bolan
Nashville Tennessee
