It is currently Thu Aug 14, 2025 5:06 pm
PostPosted: Mon Jan 15, 2007 6:58 pm
We had a pretty good coating of ice last night through this morning, and
both the single and three phase went out at my shop by early afternoon
(the 110 lines were still reading 32v). Around 10:00 PM I went by the
shop to see if it was back on yet, but no luck. As I was leaving the power
company truck came by and I walked down to the corner where they
parked to see how things were looking.
They pulled a few sections of pole out of the truck, screwed them
together and pointed it up to the transformers. While one fellow stood
back at the corner and watched, the other proceeded to whack the
transformer with his pole. Two quick taps and all the lights up and down
the street came right on. They put the pole back in the truck and drove
off.
On one hand I really wish everything were this easy to fix. On the other,
if this is the level of sophisication with which our power grid operates it's
no wonder it breaks down so often.
PostPosted: Mon Jan 15, 2007 9:51 pm
     Wow! It sounds like the ice was shunting the power. I've never heard of that! I know when I'm having a problem figuring something out I just give the head a good whack! It works!
     I wonder if I should get one of those poles!
PostPosted: Mon Jan 15, 2007 11:23 pm
Billy, if you really want one, I'd suggest you start with a PVC pipe cut to a suitable length, maybe wrap with foam insulation. If that isn't have the desired result, try a fiberglass axe handle. Now if that doesn't work, you might want to hand it over to you significant other for judicious application or just find a wall and smack your head on it.    Hope this helps.
PostPosted: Mon Jan 15, 2007 11:25 pm
PostPosted: Tue Jan 16, 2007 3:54 am
David, what you saw may have been the installation of a new fuse. When they install them they kind of whack it into place.
PostPosted: Wed Jan 17, 2007 4:22 am
First name: Martin
Last Name: Edwards
One of my mottoes on life is.....
"If it doesn't work, force it.
If it breaks? It didn't work anyway!!"
PostPosted: Wed Jan 17, 2007 6:29 am
Well they just didn't hit it hard enough, cause I'm still without power!
Kirt
Horton, MI
