It is currently Sat Jul 26, 2025 10:31 am
PostPosted: Thu Apr 21, 2005 4:00 am
OK fellas - I just got the quote to have them printed at my local Kinkos - the price is going to be 20.00 per set + shipping. My cost is a little over 5.00 per sheet - (3 sheets per plan) then I have to pick-up, collate, fold and package them. I'm not sure I can continue to do this at this price, for future orders I will bump the price up a bit, to 25.00 plus shipping. So get them now if you want'em!
I'm going to order a set for each person that spoke up in the SJ PLANS thread below - plus a few extra's. IF YOU DONT WANT TO PAY 20.00 PLUS SHIPPING TELL ME NOW and ill reduce the order by that amount
Lance
PS they should be ready in 2 weeks.
PSS DONT PAY NOW -- ill let everyone know when to pay.
LanceK38463.5434722222
PostPosted: Thu Apr 21, 2005 7:27 am
Still sounds like a bargain to me. Keep me on the list to send one to. Thanks Lance!
PostPosted: Thu Apr 21, 2005 8:59 am
well do Dave -
I just wanted to give everybody an opt out option (G)!
PostPosted: Fri Apr 22, 2005 4:57 am
Lance I'd like a set.
PostPosted: Fri Apr 22, 2005 4:59 am
Hey Lance...
Since I am new to guitars....these plans sound IDEAL!!
Put me down for a set, please.
Thanks!
Tom
PS....Any other such plans out there for various sized guitars?? Let me know.....
"By the hand of one man".......
Doc's Stringed Instruments, Doc's Mandolins
http://www.docsmandolins.com
PostPosted: Fri Apr 22, 2005 5:14 am
First name: Scott
Last Name: Thompson
What became of the idea of electronic copies? Are those available also?
Scott Thompson
Port Townsend,WA
-Billy Bragg
PostPosted: Fri Apr 22, 2005 5:20 am
I can provide DWF electronic files but not all Kinko's and such printing companies can print them or are willing to install the software to print them. we are still trying to work out the kinks. It may be that PDF files will have to be the format but I don't have the software to write to a PDF.MichaelP38464.5990856482
PostPosted: Fri Apr 22, 2005 1:28 pm
First name: Scott
Last Name: Thompson
[QUOTE=MichaelP] I can provide DWF electronic files but not all Kinko's and such printing companies can print them or are willing to install the software to print them. we are still trying to work out the kinks. It may be that PDF files will have to be the format but I don't have the software to write to a PDF.[/QUOTE]
So how do I go about getting those instead of the hard copies?
Scott Thompson
Port Townsend,WA
-Billy Bragg
PostPosted: Sat Apr 23, 2005 2:53 am
For making a copy of guitar plans my local print shop sent me to a company that prints constructions site plans. If a town has an architect in it there should also be someone who prints plans that size. Would a company like that be able to print DWF files?
PostPosted: Sat Apr 23, 2005 3:05 am
Got ya Jim --
Im going to order 20 extra sets for late comers
PostPosted: Thu Apr 28, 2005 9:00 am
Hello Lance,
I'll take a set too, if it's not too late.
-C
PS I can print from electronic file if that's easier.Chas Freeborn38470.751099537
Freeborn Guitars
and home of BeauGuard©
PostPosted: Thu Apr 28, 2005 9:16 am
sure thing -
PostPosted: Thu Apr 28, 2005 2:09 pm
First name: Raymond
Last Name: Lee
City: Elmhurst
State: Illinois
Zip/Postal Code: 60126
For the plans, is a DWF file compatible with Autocad? If so, is it possible to get an electronic copy of the plans?
Ray
PostPosted: Thu Apr 28, 2005 10:08 pm
Hi Ray - I should let Michael Payne answer this, but I believe Yes - a DWF file is compatible, as Michale did these using autocad.
PostPosted: Fri Apr 29, 2005 12:13 am
Ray, DWF is an view only Autodesk format designed to allow end user to view and print only,AutoCad drawings. You can not copy the file, rename the file or alter in any way You can only view and print from AutoDesk's DWF Viwer software. You can not view in AutoCad. This is so that your work is 100% write protected. The viewer software is free. This is AutoDesk's answer to PDF. So If your question is can I open this file in AutoCad the answer is no. If your question is is this a file generated by AutoCad the answer is yes. You can get the free viewer and learn more about the format at www.AutoDesk.com
PostPosted: Fri Apr 29, 2005 12:23 am
Thats why I should have let Michael Answer
PostPosted: Sat Apr 30, 2005 4:11 am
lance
i may have been under the apparent misapprehension that your use of the term sj for these plans was in keeping with the long accepted useage of sj to refer to the gibson southern jumbo,or j45 type. discussion in another thread has caused me to think i may be incorrect. could you please clarify.crazymanmichael38472.5603935185
PostPosted: Sat Apr 30, 2005 6:46 am
Small Jumbo, more akin to a J-185 than a Slope-D.
PostPosted: Sat Apr 30, 2005 1:11 pm
lance
don, in his above post, has confirmed my misunderstanding of your use of the term sj. i realy have no interest whatsoever in building anything in the shape of a j185.
if you can find anyone interested in the two sets i ordered it would be appreciated.
PostPosted: Mon May 02, 2005 1:27 am
Hi, so just to make sure, are the OLF SJ plans like the Olson at all as far as upper and lower bout and waist measurments?
PostPosted: Mon May 02, 2005 1:45 am
Michael Payne will chime in here with the dimentions.
PostPosted: Mon May 02, 2005 1:53 am
Correct me if I am wrong but did not Olson base his SJ on the J-185 shape, just smaller? I seem to recall Olson saying that onece. A J-185 shape coser to the size of an OM.
PostPosted: Mon May 02, 2005 4:08 am
I didn't have Olson's dimension. I got my dimensions from Lance's old SJ form that I bought from him early this year. Until I bought the form from Lance I had not built SJ's. The dim's are:
15 1/2 LB
11 5/8 UB
19 15/16 body LEN.
4 1/2 Max Depth
3 7/8 Min Depth
6 from neck/body joint to center of soundhole
6 3/4 from neck/body joint to centerline of waist valley
9 3/4 waist valley to waist valleyMichaelP38474.5980902778
