It is currently Sat Jul 26, 2025 10:05 am
PostPosted: Sun May 01, 2005 2:02 am
I know stewmac has it - but im guessing you can get it else where - a google search has turned up nothing -
80, 120, 220 and 320 are the grits im interested in.
PostPosted: Sun May 01, 2005 3:56 am
Have you tried a body shop supply store? They have most of the stickit type papers in stock for all those DA sanders bodymen use.
I've found a lot of stuff at the one here.
PostPosted: Sun May 01, 2005 4:06 am
I had bought a bunch off of ebay a couple of years ago.
Ya might try there.
Gary
PostPosted: Sun May 01, 2005 4:35 am
Hi Lance!!!
How many sheets of each grit are you interested in???
Walter
PostPosted: Sun May 01, 2005 5:16 am
Walt -
The stuff that stewmac sells is in a roll - thats what im after - so i can stick it to the bottom of my radius blocks.
PostPosted: Sun May 01, 2005 5:23 am
i use somethng cheaper for my radius blocks, but use the gold with the adhesive removed for easing neck heels in the initial set and for resets. the film slides slickly between the body and neck heel.
wish i could offer a cheaper place to obtain it then stew- mac but i've searched in vain as well. has to be one but i've not found it.
PostPosted: Sun May 01, 2005 8:46 am
Lance give this link a try!
PostPosted: Sun May 01, 2005 9:19 am
Lance
I have have looked but have not found. And the stuff you speak of is the best! (I think so anyway). Very pricey around $48 per roll. I bit the bullet and paid the money . 80, 120 ,220, and 320. I use the 320 for fret leveling. Nothing else works as well. 80 and 120 for neck setting. Let me know if you find a cheaper supplier! PLEASE!
PostPosted: Sun May 01, 2005 9:58 am
Oops.Don A38473.796099537
PostPosted: Sun May 01, 2005 2:29 pm
thanks don
still not cheap but better than the alternative!
PostPosted: Sun May 01, 2005 4:07 pm
It appears the stuff is made by 3M automotive. The mylar backing implys wet sanding, I think. I did see it for $35 a roll at one of the automotive places.
PostPosted: Sun May 01, 2005 10:52 pm
First name: Nelson
Last Name: Palen
Possible source?
Wondering if this is an import alternative?
Nelson
PostPosted: Sun May 01, 2005 11:04 pm
Nelson, I've tried that Grizzly stuff. It's FAR from the 3M paper. Loses it's cut very quickly and loads like nobody's business. That said, it seams to work for the down and dirty stuff but I don't care for it in finer guitar work.
PostPosted: Sun May 01, 2005 11:05 pm
the grizzly stuff is paper backed, not mylar. don't know if the abrasive is similar or not.
PostPosted: Mon May 02, 2005 8:52 am
First name: Nelson
Last Name: Palen
Thanks for the heads up, guys.
Nelson
PostPosted: Mon May 02, 2005 10:34 am
Lance...
R.S. Hughes Co is a national supply firm that handles 3M...plus other stuff. I use them out of Sacramento Ca for the 3M Stikit. Check here for a location near you or use their web site to order.
           http://rshughes.com/locationfinder/
PostPosted: Mon May 02, 2005 10:09 pm
BINGO! Thanks Hank!
1 ROLL 3M(TM) Stikit(TM) Sheet Roll 415U, 2 3 / 4 in x 25 yd 80 A weight, $15.37
1 ROLL   3M(TM) Stikit(TM) Sheet Roll 415U, 2 3 / 4 in x 35 yd 120 A weight, $21.43
Total $36.80
No thats what im talkin'bout!
PostPosted: Mon May 02, 2005 11:48 pm
lance
better check again. i believe you were looking at something other than the gold rolls you want.
PostPosted: Tue May 03, 2005 12:02 am
This it?
3M
The price seems more in par --
Dang it all! Still you get 10 more years of it for 10.00 less - not to bad.LanceK38475.3781018518
PostPosted: Tue May 03, 2005 3:15 am
yes, but i think don's link to the autobody store is about $4.00 cheaper, that is unless you go for the 10 x lifetime supply!
PostPosted: Tue May 03, 2005 7:20 am
If you want it by the sheet in smaller quantities, you can get it from here. You will pay more in the long run though. I think this is the stuff you're talking about.
http://www.homesteadfinishing.com/index.html
