It is currently Wed Aug 20, 2025 12:02 am
PostPosted: Sat Jan 27, 2007 10:58 am
I've got what I call tear out because I can't think at the moment of the
right term - when I bent my side (well, fwiw, we're actually talking about
an a-style mando rim), I did so slightly too agressively in a couple of
places and small sections of grain tore loose from the surface - not full-
on cracks or breaks, but I've got to do something with them. My instinct
is to use CA and then sand down. I've got plenty of thickness in the rib to
do so.
Is that pretty standard operating procedure?
PostPosted: Sat Jan 27, 2007 11:13 am
I assume this is maple, yes? And it sounds like what I call flame lifting. (though that is probably not even close to the real name)
Yes, you can lay it back down but I'd recomend using white or titebond glue. CA might sort of highlight the lift. HHG will also work very well.
PostPosted: Sat Jan 27, 2007 11:44 am
What Paul said is the right thing to do, Jay. Also, I would clamp them with
hardwood cauls shaped with the same radius as the side where the break
is. (inside and out) Wrap them with wax paper and clamp them pretty
dern tight. You probably wont have to sand very much at all.
long
PostPosted: Sat Jan 27, 2007 12:27 pm
use Hide glue or white glue not CA, and clamp them back into shape. Sand
them and you should not hardly notice it. If you use CA on Maple for this it
will stand out horribly. CA works well in this situation for dark woods.
edit..I just noticed I just repeated what others have already said...oh well..
PostPosted: Sat Jan 27, 2007 2:53 pm
It's actually sapele. This is my mando-out-of-what's-laying-around
project...basically all mahogany.
PostPosted: Sat Jan 27, 2007 3:01 pm
CA will still show way too bad in Mahogany...go with hide glue for the most
invisible repair.
PostPosted: Sat Jan 27, 2007 11:14 pm
Any chance commercial liquid hide glue in a bottle will work similarly to
regular hide glue in terms of effectiveness and invisibility? I typically use
white glue for my builds and am not set up for hot hide glue.
Thanks for all the advice, I really do appreciate it!!!
Jay
PostPosted: Sun Jan 28, 2007 1:32 am
[QUOTE=ecklesweb] Any chance commercial liquid hide glue in a bottle will
work similarly to
Jay[/QUOTE]
In a word... NO. the "liquid hide glue" stuff is not good at all. Use your
white glue. Make sure the peeling closes all the way up so the glue line
won't be noticeable, and you'll be fine.
cron
