It is currently Sat Jul 26, 2025 10:05 am
PostPosted: Tue May 03, 2005 3:03 am
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
How fine -grits- do you sand tops and b/s before applying epoxy. How fine between coats of finish?
Do I need to use microbeads with System 3 for filling Macassar-if so what proportions?
PostPosted: Tue May 03, 2005 3:13 am
Straight grained mahogany or EIR, and tops, P220 works fine, although P320 is a bit 'safer', perhaps. P400 is as far as I feel is necessary for a laquer finish guitar. If I'm oiling something, I go all the way to 1500 and steel wool.
I sand to 320
PostPosted: Tue May 03, 2005 3:28 am
220 is fine for epoxy and Laquer. Oil finish is different, you have to go much higher.
PostPosted: Tue May 03, 2005 3:33 am
First name: Harald
Last Name: Lane
City: Vienna
Country: Austria
Hi Bob!
Sand to P320, safest way to remove all scratches. I don?t recommend the use of microbeads with epoxy for porefilling, because this are small glassbubbles. I use instead an Thickener called Aerosil. Its easier to squegee it into the pores, the result is much better.
http://www.hl-guitars.at
PostPosted: Tue May 03, 2005 7:38 am
Bob, you asked about sanding tops before epoxy filling. I sand tops to P400. You do not need to fill tops such as spruce or cedar. just a seal coat of shellac is all that is needed on spruce and cedar tops.
I don't use microbeads except on very porous woods.
PostPosted: Tue May 03, 2005 8:01 am
Last Name: Johnson
State: CO.
Thank you all. Very helpful.
