It is currently Wed Aug 20, 2025 6:05 pm
PostPosted: Thu Feb 08, 2007 1:58 am
I received a package from John Watkins the other day and have been trying to put some pics up so everyone could see his nice work. Unfortunately I am having trouble with my website and it took a while to get them up where I could post them.
The first two pics are of a peghead jig that John made for me. It uses vacuum to clamp it to the headstock and then I can use a pattern routing bit to cut the shape. It also has drill bushings installed so the tuner holes are always in the right place.
I just wanted to say that John and I worked this out in about 15 mins over the telephone and I sent him a really crummy photocopy of my old plywood jig to work from. John cleaned up all the curves, figured out what all was needed for the vac setup and milled it out of a nice big hunk of aluminum. Thanks for all your help John!
Oh yeah, here are the pics.
The front.
The back.
I am still trying to get some pics of the neck I bought from John up here also. It is a walnut neck with a maple/mac ebony/maple center stripe. If I can ever get it loaded to my website, I'll put it in this thread as well.
Thanks again John!!!
PostPosted: Thu Feb 08, 2007 2:12 am
Very Cool!!! Nice work John...and Dave too. I assume the bushings are loosely fit, and when you pattern rout the beadplate they are easily removed?
PostPosted: Thu Feb 08, 2007 2:14 am
Man that is sweet!
PostPosted: Thu Feb 08, 2007 2:37 am
[QUOTE=JJ Donohue] I assume the bushings are loosely fit, and when you pattern rout the beadplate they are easily removed?[/QUOTE]
You are correct JJ. The bushings pop right out for the pattern routing and then when the routing is finished you just turn it over, pop the bushings back in and drill the tuner holes.
Can you tell I'm very pleased with John's work?
PostPosted: Thu Feb 08, 2007 3:51 am
First name: Tom
Last Name: Dowey
City: Sudbury
State: Massachusetts
Zip/Postal Code: 01776
Looks very cool. How do you align it? Is there a centerline on the jig?
PostPosted: Thu Feb 08, 2007 3:59 am
John, you did it again.....a real winner!
PostPosted: Thu Feb 08, 2007 6:59 am
Last Name: Watkins
City: Lake Zurich
State: IL
Thanks for the nice comments, guys. I'm glad you're happy with the fixture and the neck, Dave.
Tom, yes there is a centerline engraved in it as well as a zero fret line. The fixture extends past the nut to avoid gouging the neck when pattern routing.
John Watkins
CNC Guitar Parts
PostPosted: Thu Feb 08, 2007 7:26 am
Thanks for answering that John, I've been out of the house for a while.
The only problem with alignment is the centerline is on the vac side of the jig. I am just going to use a square and a scribe to mark it on the ends of the jig so I can see where to center it.
Did I mention, I love this jig!
PostPosted: Thu Feb 08, 2007 11:30 am
Finally, here's a pic of the neck John made for me. It is walnut with a maple/mac ebony/maple center strip and a mac ebony backstrap on the peghead.
Pretty cool, huh?
PostPosted: Fri Feb 09, 2007 12:47 am
Bump.
Just wanted everyone to see one of John's necks.
PostPosted: Fri Feb 09, 2007 12:52 am
Here is some more of Watkins handy work!
Just got these yesterday. The slot head is for my little Cocobolo Redwood 0-12 and the ebony is for an OMFS.
PostPosted: Fri Feb 09, 2007 1:03 am
Thats a great lookin' neck Dave and your headstock jig is really something!!Great work as usual from John W.
PostPosted: Fri Feb 09, 2007 1:08 am
Very nice Lance! I really like your logo!
PostPosted: Fri Feb 09, 2007 1:30 am
Thanks Hesh! The neck is going on a mac ebony b/s dred with an adi top. I think it will be a nice combo.
PostPosted: Fri Feb 09, 2007 5:19 am
