It is currently Wed Aug 20, 2025 2:21 pm
PostPosted: Mon Feb 12, 2007 9:03 am
The vacuum holder sold by lmii looks like a nice solution for holding the guitar, but I was told the pump has to run continuously while holding the guitar, is the pump unpleasantly loud and noisy? Also, do you have time to catch the guitar in the event of a power failure.
PostPosted: Mon Feb 12, 2007 9:09 am
Build the system that Joe Wood worker has on his site... You don't need to run it continously.
PostPosted: Mon Feb 12, 2007 9:19 am
I agree
I just finished building the Joe Woodworker EVS system. Since in has a
subresevoir and 2 main resevoirs it doesn't need to run continuously
Brock, I'm a little lost on the Joewoodworker site, found a lot on veneer clamping but didn't find a holder system of any kind. I assume you meant there was a pump system that works with the lmii holder? If so, which one?
PostPosted: Mon Feb 12, 2007 9:25 am
Yes the joe woodworker site is about the pump systems. I built the EVS
system with a Gast pump and it is very nice. You could just use the pump
directly, but the EVS system has reservoir tanks to keep it from running
continuously. Also, the controller allows the pump to kick on if their is a
drop in vac by 4. Very well designed and easy to build. I also use the foot
switch which allows you to turn it on and off without dumping the vacuum
pressure. A very nice addition to the system.   I have the LMI holder and it is
very well designed.
PostPosted: Mon Feb 12, 2007 9:26 am
Thanks Andy,
How often does the EVS system have to cycle while holding a guitar?
PostPosted: Mon Feb 12, 2007 9:28 am
It depends on how airtight your system is. I would say every 10 minutes or
so. And when it does it only does it for a few seconds to recharge.
Marc, it depends on how tight your system/seals are. Mine cycles for about 1 minute about every 10 minutes when I'm on the pod. My clamping drawer is much more often as it's not very tight.
PostPosted: Mon Feb 12, 2007 9:29 am
and which model Gast pump did you use?
PostPosted: Mon Feb 12, 2007 9:35 am
I have the 5.5 CPM double piston. You could use a cheap refrig pump, but
they may not pull enough vacuum
PostPosted: Mon Feb 12, 2007 9:36 am
Thanks everyone, I think I understand now.
PostPosted: Mon Feb 12, 2007 10:14 am
[QUOTE=azimmer1] It depends on how airtight your system is. I would say every 10 minutes or
so. And when it does it only does it for a few seconds to recharge. [/QUOTE]
and how big your tanks are. I went with 2 30" tanks rather than 2 15" and mine only runs every 15 minutes or so.
