It is currently Wed Aug 20, 2025 4:36 pm
PostPosted: Wed Feb 21, 2007 6:32 am
I am wondering what some of you think? Do you radius the large brace abovt he soundhole or leave it flat.What are the advantages of the two options?
Thanks, Steve H.
PostPosted: Wed Feb 21, 2007 6:55 am
First name: Hank
Last Name: Mauel
Zip/Postal Code: 95603
Mine is flat due to the geometry of my top design AND my end block/fingerboard support system...which you can see in the "Jigs and Tools" section of the forum.
The brace itself tapers from the center down to about 1 1/2" form each end, where it then is scalloped and is tucked into the kerf lining with the upper legs of the X brace. I adjust my truss rod from the soundhole, so there is a 1/4" diameter access hole drilled in the center of the brace at it's tallest point.
Hank Mauel
PostPosted: Wed Feb 21, 2007 7:08 am
mine is flat in the middle where the fingerboard extension will be glued, but the last couple of inches on each end have the same radius as the rest of the top.
                       Paul
PostPosted: Wed Feb 21, 2007 7:46 am
I use flat upper transverse braces.
-j.
-jack handy
PostPosted: Wed Feb 21, 2007 9:14 am
Mine is flat since it fits my neckblock design well.
PostPosted: Wed Feb 21, 2007 10:26 am
Flat to keep everything lined up nice.
Blake
