It is currently Wed Aug 20, 2025 4:37 pm
PostPosted: Thu Feb 22, 2007 5:18 pm
I just had an inlay redone and the area left from another inlay was filled with ebony dust and CA. Now there is a visible "shadow" on the headplate next to the new inlay. I thought the finish would conceal this but it doens't seem to help...
Anyone have a way to help this issue?
PostPosted: Fri Feb 23, 2007 12:22 am
Peter,
The filled routing is quite noticeable.
If it were me, I think I would jut replace the headplate...Sorry I don't have a better idea for ya!
PostPosted: Fri Feb 23, 2007 2:19 am
There is no finish on the headstock now... I thought about dying the headstock but I'm afraid to get it on the bindings.
PostPosted: Fri Feb 23, 2007 2:31 am
Hi Peter,
Have you tried to lightly/carefully sand the shadow, sometimes that seems to really help when using CA and dust on ebony.
Greg
Gwaltney Guitars
PostPosted: Fri Feb 23, 2007 4:13 am
Don't mean to be nosy..but did you have this done by someone else and they sent it back to you this way?
PostPosted: Fri Feb 23, 2007 4:15 am
EDIT>>>Don't answer my above question if you feel you are putting someone on the spot...
PostPosted: Fri Feb 23, 2007 4:30 am
Last Name: Abercrombie
Replace the headplate- that's my suggestion. Once somebody starts to look carefully- and the logo is a magnet for close inspection- they will notice even the best cover-up.
It's a chunk of cash to by/make(?) a new headplate, but will probably be quicker than fiddling with micro touch-ups for hours.
Well, the reason there was the need to redo the original inlay is because the one I did was not up to my expectations so I had it redone. So the new font did not cover the old inlay totaly.... I can always remove the headplate and start over but OBVIOUSLY I am trying to avoid that...
PostPosted: Fri Feb 23, 2007 10:03 am
Since it's still unfinished, why not rub a little shellac on it and see what it will look like. The shellac is easily removed and will let you know if it will look right under finish.
PostPosted: Fri Feb 23, 2007 10:52 am
    I hate to say this but the pearl is very nice the actually inletting gaps are too heavy to hide well. They are many ways to inlet . I don't use dust as a fill as the dust tends to halo. I will color the glue as this seems to work better.
    I did a little seminar at Sylvan Wells shop a few weeks ago. I use a sharpie , some activator and superglue. This works very well for filling voids on inlay works.
     I do like the idea of seeing what it would look like under a finish first. It may not look as bad as the reflective qualities of the glue in the dust may be magnifying this
john hall
PostPosted: Fri Feb 23, 2007 10:56 am
First name: Craig
Last Name: Lavin
City: Sunrise
State: Fl
Zip/Postal Code: 33323
1) Rout out the glued area, AND the inlay in a pattern that can be variable but re-inlaid cleanly.
2) Make sure the grain and wood type is similar, and insert a new wood plug as if you were inlaying it clean.
4) Sand and level the plug.
5) Re-inlay a new inlay.
Finish- and then go over the ebony with ebony dye like a fingerboard. It will even out any wood quality imperfections.
If done properly it should be invisible.
OR- just try dying the veneer as is first- it may darken out the headplate so that the new darker area isn't as noticeable.
Good luck.
Craig Lavin
www.handcraftinlay.com
PostPosted: Fri Feb 23, 2007 4:49 pm
I certainly don't have the chops that our two inlay experts above have, but I have another suggestion.
Why not glue down a piece of 0.020" black fiber over top of the face. You would have to re-do the binding, but you could easily re-route the inlay channel using the existing channel as a guide, use a small dia bit around the edges, than just drop the fiber down into the cavity to gain back your height.
