It is currently Thu Aug 21, 2025 12:22 pm
PostPosted: Fri Mar 16, 2007 11:41 am
What's the name of the industrial supply house that sells the string steel by the roll?
Also what thickness do you guys use for your benders?
TIA, John
PostPosted: Fri Mar 16, 2007 12:31 pm
Thanks Michael, I just found & ordered some from MSC.
PostPosted: Fri Mar 16, 2007 3:45 pm
John,
   I purchased a few rolls from McMaster Carr. I purchased the .007 Blue Tempered Spring Steel. I recently purchased a roll of .015 Stainless for a new bender I am working on and it seems thick. Probably .010 would be good.
Brad
Avon, OH
PostPosted: Fri Mar 16, 2007 6:39 pm
I believe that .010 is indeed the gauge of choice for blued steel slats John.
PostPosted: Fri Mar 16, 2007 9:38 pm
The stuff I ordered is.012" thick so I think it'll be fine. MSC also has 6"x50" pieces so you don't have to buy 20 ft to get a couple of workable slats.
PostPosted: Sat Mar 17, 2007 1:08 am
John,
   Are you making some mods to your bender?
Brad
Avon, OH
PostPosted: Sat Mar 17, 2007 7:40 am
First name: Coe
Last Name: Franklin
City: Decatur
I`m looking for some slats as well. How long/ many uses does one get before they get brittle, or will they?
PostPosted: Sat Mar 17, 2007 3:07 pm
I have found that .015 is what you need. I carry them and they are in stock. Check out my online catalog.
john hall
PostPosted: Sat Mar 17, 2007 4:57 pm
[QUOTE=Brad Way] John,
   Are you making some mods to your bender?[/QUOTE]
No, just replacing the wornout slats
