It is currently Thu Aug 21, 2025 3:40 am
PostPosted: Sun Mar 25, 2007 2:11 am
Hi, I see these guys making these beeeeutiful laminated necks and then they lay a templet on the side to mark out the position of the necks,wpe9.jpg 7052 bytes where do you get the templets? do you make them? thanks, Red
PostPosted: Sun Mar 25, 2007 3:05 am
I made my own. I bet John Watkins could make you one if you don't want to.
PostPosted: Sun Mar 25, 2007 3:16 am
Thanks Rod, now how would I get up with John Watkins?
                                        thanks, Red
PostPosted: Sun Mar 25, 2007 3:58 am
He's one of the many great OLF sponsors. Check out his site by clicking the link above or just by clicking here.
Now, he doesn't have templates listed on his site, but like I said, if you ask him, he may be willing and he is certainly able.
PostPosted: Sun Mar 25, 2007 4:38 am
a template is a very easy thing to make yourself. thin plywood, hardboard, mdf, plastic, sheet metal, dense card stock; all will work well. i prefer plastic or thin birch ply.
a few minutes with a pencil or marking knife, a ruler and a protractor is all that is necessary to lay it out. then cut on the bandsaw or whatever.
obviously, different templates make laying out different scale length necks easier, but it is possible to use one template with index marks or pins to lay out different scale lengths so long as the other details are the same, but this may make errors easier to creep in.
PostPosted: Sun Mar 25, 2007 1:19 pm
I prefer 1/2" Birch plywood too. Used oak plywood once but the open grain is difficult to draw fine lines on.
What I dont like about MDF is that it can break. I use two-sided carpet tape to attach templates and they require some force to remove.
