It is currently Thu Aug 21, 2025 5:38 am
PostPosted: Fri Mar 30, 2007 11:15 pm
I have never used anything other thana straight 16" Martin style fingerboard. I want to consider options before starting my next build. I was thinking about a 16-20 compound. Can I please get a quick education? Maybe I'm missing the boat here by not using a compound FB.
PostPosted: Sat Mar 31, 2007 12:16 am
16" here...Reason...tradition
I believe that more electric guitars use compound radii than acoustics.
On those builders who use the compound,I'd be interested in learning more as to the rationale and benefit.
PostPosted: Sat Mar 31, 2007 12:43 am
i've used both, with the compound being an upcharge since i did them by hand.
i would recommend the compound to those players who do a lot of bending since it reduces the likelyhood of buzzing on the higher frets.
i bought the plans for craig's radiusing jig but haven't got around to building it as yet. when i do, this option will be a lot easier to produce.
it should be noted that many older martin boards have a compound radius, approx. 16-20.
