It is currently Thu Aug 21, 2025 6:25 am
PostPosted: Thu Apr 05, 2007 2:23 pm
Hi ...I hope have a go at  binding my guitar in the next week or so. I bought ebony bindings a while ago to do this. I have since been reading ( in preparation) that ebony can be difficult to bend. I just have my trusty hot pipe as my bending method.
Have I chosen a tough wood to bend  for a rookie. My only other guitar was bound in what I guess you would call " ebonoid"...wood fiber stuff I think it was...it went pretty easy...I didn't even have to pre bend it at all.........I liked the colour, so I thought this time I'd try the real thing...any secrets to making my attempt go smoothly( if that's possible)....it may be one of those weeks!!
Cheers...and thanks..
PostPosted: Thu Apr 05, 2007 2:30 pm
Irwin,
I just posted pics of my first guitar, and used ebony bindings.  Bending was ok - used a fox style bender.
Doug
PostPosted: Thu Apr 05, 2007 2:31 pm
My first four guitars all have ebony binding, so I've bent 16 pieces, broke one. All bent with light bulbs on a fox style bender, for dreadnaught guitars. I tape them together with blue masking tape and bend just like I bend the sides. Spritz with water lightly. Didn't seem hard to me, but I don't know about a pipe.
PostPosted: Thu Apr 05, 2007 2:49 pm
Last Name: Abercrombie
I've bent one set of ebony binding (4 pcs) and didn't have much trouble at all.
I soaked them in water for an hour or so (Mario-style sewer pipe) and wrapped them in foil.
OOO shape in a Fox/Doolin bender with heat blanket.
I also bent some ebony for binding around headstock curves, using a hot pipe-type electric iron.
I think that it may depend a lot on the stick that the bindings came from. Some ebony I've come across has been a bit splintery, but my bindings bent like (stiff) plastic when hot.
You have to get the shape exactly right as you won't be able to pull the bindings tight easily- they're stiff when 'set'. An iron is handy for touch-ups at the waist area.
Good luck!
PostPosted: Thu Apr 05, 2007 3:29 pm
Well I don't remember exactly how many I broke trying to bend over a hot pipe but it was quite a few. Then someone suggested thinning to .060 and viola they bent pretty easy.
Now .060 may be on the thin side for some but just add a .020 black perfling on the inside and it now looks like a .080 binding. I use a fox bender now and they bend pretty easy at .080
PostPosted: Thu Apr 05, 2007 4:45 pm
A wet rag is a good thing to have handy by the bending iron as well. Sometimes a good steaming is needed to get things loosened up.
It all depends on the stick, I think.
