It is currently Wed May 21, 2025 4:18 am
PostPosted: Fri Apr 06, 2007 11:32 am
I have a Porter Cable 690 that I want to use in a table set up. I was just wondering if it is worth getting a 1/2" collet? Any thoughts or insights?
PostPosted: Fri Apr 06, 2007 12:23 pm
yes. they are usually available on ebay for $10-$12.
a 1/2" shank bit is much more rigid and less prone to breakage and vibration. i use a 1/2" whenever possible.
PostPosted: Fri Apr 06, 2007 3:41 pm
First name: Hank
Last Name: Mauel
Zip/Postal Code: 95603
[QUOTE=crazymanmichael] yes. they are usually available on ebay for $10-$12.
a 1/2" shank bit is much more rigid and less prone to breakage and vibration. i use a 1/2" whenever possible.[/QUOTE]
What he said!
Are you also considering a "router lift" unit? It makes setting heights of cuts REALLY easy and most will take the PC690 as a standard set up.
I've got one on my router table and it is invaluable.
Hank Mauel
PostPosted: Fri Apr 06, 2007 4:39 pm
Thanks guys. Much appreciated.
PostPosted: Sat Apr 07, 2007 12:55 am
The only time when it is better to not use a 1/2" collet in a router is when the bit diameter is less than 1/4". In that case it is better to stick with the 1/4" collet as the shaft of the bit is the same throughout.
PostPosted: Sat Apr 07, 2007 5:15 am
Thanks Shawn.
PostPosted: Mon Apr 09, 2007 3:21 am
What Shawn said.
Ever since getting my 1/2" collet, I won't use 1/4" bits unless I really have to (ie, truss rod slots, CF slots). Especially for heavy work, it adds monstrous amounts of stability.
I'm pondering getting a second router - either another 690 or an 890 - for my table; I use my 690 for so many tasks I don't feel like having it tied up in the table!
