It is currently Sat Aug 09, 2025 3:16 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Fri Apr 20, 2007 5:04 am
[QUOTE=Howard Klepper]
I think I get it--I could set the angle of a straight blade in a toolpost and use the cross slide to cut the taper. But diameters as well as taper are critical for a bridge pin.
Thanx Billy[/QUOTE] Howard,
Angles are the least precise settings in machining, and the hardest to measure accurately.
Diameters are very easy. I think I would make a tool to cut the pins very much like a pencil sharpener. I think I would try to make it from hard steel with a tapered hole and a slot, no blade. Use the sharp slot edge to do the cutting.
PostPosted: Fri Apr 20, 2007 5:16 am
You could probably make it by drilling the hole in a block, ream it out with the proper taper reamer, cut the corner out with a pair of 90* cuts, then put a burr on one edge, much like you would a scraper.  If not, just make it out of hardwood, and use a utility knife blade mounted at the correct angle, and at a height in the cut out that would put it at the proper position to shave the material off, just like a pencil sharpener.
PostPosted: Fri Apr 20, 2007 7:15 pm
[quote]But diameters as well as taper are critical for a bridge pin.[/quote]
   I'm refering to working in metal, comparativly, wood is wide open. Wish I had a camera I'd do a Hesh style tutorial!
PostPosted: Sun Apr 22, 2007 10:17 am
You could get one of those little (toy) wood lathes that pen makers use. They are small, inexpensive and just the right size for pins. Do not get a bloody great huge lathe, or the missus will keep on at you until you make that four poster bed she's always wanted - ask me how I know.
Now, why someone would want to spend all their free time making pens is beond me...
Check that angle out and I think you'll find what you're looking for.
