It is currently Fri Aug 22, 2025 11:41 am
PostPosted: Sun May 06, 2007 7:10 am
I like to keep my backs at .100-.110 depending on the wood.
what do you guys do? I have a Tazmanian Blackwood set thinned out to .095" is that too thin?
PostPosted: Sun May 06, 2007 7:55 am
I've gone as low as .065, and it worked great. Normally my backs are
around .070-.090 depending on stiffness and weight.
PostPosted: Sun May 06, 2007 8:04 am
I usually don't allow a back or side to stay over .085". Of late my little guitars are around .070" on the back and sides.
PostPosted: Sun May 06, 2007 11:33 am
I to have found thinner backs on my guitars. It started by accident and I will to backs normally at .090
john hall
PostPosted: Sun May 06, 2007 12:04 pm
I used to do all mine at .100" but I guess I'll go thinner now!
PostPosted: Sun May 06, 2007 1:09 pm
I'm using about .07-.075 on backs & sides, and about .065 on cutaways. These are for 000 and smaller guitars. For larger SJ's, I'll go to .080 on backs.
Jimmy Caldwell
PostPosted: Sun May 06, 2007 1:33 pm
I stay at 0.095" or a little below for Mahogany and Walnut. Anything
dense like the Rosewoods go to about 0.080" to 0.085". I could go
thinner but find that once I put the back bracing on - these thicknesses
work really well for me. If you go to thin with the hardwoods, they loose
that "ping" sound. I try to go as thin as possible and still retain the sound
I am looking for. However, I would rather go thinner than be on the too
thick side.
Peace Out,
Simon
PostPosted: Mon May 07, 2007 12:10 pm
Hold them up to the light, if you can read a newspaper through it, you might be to thin! anything less and they are probably ok
I take mine down to .070-.080 depending upon the wood
PostPosted: Mon May 07, 2007 4:01 pm
    I finish up with the following dimensions depending on stiffness.
Back - .070" to .090"
Sides- .070" to .080"
Top - .100" to .125"
Cedar tops can finish up as thick as .145" depending on the piece.
Regards,
Kevin Gallagher/Omega Guitars
PostPosted: Tue May 08, 2007 3:11 am
Thanks Kevin!
PostPosted: Tue May 08, 2007 4:17 am
I'm about spot on with your dimensions Kevin as it would have it...
PostPosted: Tue May 08, 2007 6:47 am
I thickness down to - .080 to .085 on my backs
