It is currently Fri Jul 18, 2025 9:32 pm
PostPosted: Sun May 13, 2007 8:12 am
Hi, what does evrybody use to trim the excess of the top and back flush to the sides, before the channels are cut?
pictures would help.
                        Red
PostPosted: Sun May 13, 2007 8:13 am
Red,
I use my binding jig with it set to cut flush to the sides.
PostPosted: Sun May 13, 2007 8:18 am
Red,
just watch for grain orientation so the soundboard wont split or tear...
Thanks Dave, thats what I was gonna do, I thought somebody might do it different.....
PostPosted: Sun May 13, 2007 8:33 am
I just use a lam trimer and a follower bit, but like Peter said, watch the grain.
PostPosted: Sun May 13, 2007 8:42 am
When you say watch the grain, do you mean to do the climb cut?
                                      Red
PostPosted: Sun May 13, 2007 9:27 am
Red
Check out the Stewmac site or have a look in a cattledog if you've got one.
There's a really good diagram of the sequence of cuts.
Bob Connor
Geelong, Australia
PostPosted: Sun May 13, 2007 9:28 am
Whoops. I've been Heshed.
Bob Connor
Geelong, Australia
PostPosted: Sun May 13, 2007 9:31 am
I use my router table with a flush trim bit. Like everyone says, watch the grain direction to avoid tear-out (or tear-off, to be more precise).
PostPosted: Sun May 13, 2007 10:32 am
Good advice to watch the grain. I didn't do this on one of mine and two chunks of spruce went flying! Luckily I found them and was able to glue them back in place. Lesson learned!
PostPosted: Sun May 13, 2007 11:32 am
I do exactly what Hesh does. It's worked flawlessly twice so far.
PostPosted: Sun May 13, 2007 11:40 am
Red,
that Stewmac example is a great way to do it.
PostPosted: Sun May 13, 2007 11:43 am
i've got the 'guitar jigs' router jig and it's got a flush trimming guide which works fast and great. the problem is that i'm currently working on wenge back and sides and feel certain that pieces might go flying if i ask the router to take off excess back that is not glued onto the rims/kerfing.
so for this one, as painful and time consuming as it is with wenge, i'm cutting close to flush with a dozuki saw (can cut just about everywhere but the waist), then sanding to flush. it's a lot of work, but i don't want to risk the splinters.
my plan before routing is to coat the edges to be routed with zpoxy first. hoping a dry layer of that keeps the wenge from blowing apart.
phil
PostPosted: Sun May 13, 2007 1:46 pm
I just did the trimming last week on my Celtic build. Here is a photo doing the climb cuts. Notice an arrow drawn on the guitar holding jig that reminds me where to stop and start the cuts.   In the 2nd photo, I've just finished trimming the top and you can see the Williams jig. I use a spiral downcut bit.
PostPosted: Sun May 13, 2007 2:57 pm
This is one post where I wish Mario was back.
He posted his method on the MIMF a while back and I have to say that it's the best method I've ever seen to trim the excess top and back material.
I searched over on the MIMF for the thread but they have such a poor archive (read slow) system that it's just floating around in cyberspace or something
Anyway, he uses those little roto-zip guide point bits like this
The bit is 1/8" dia, runs it in his router table.
Picture in your mind the setup (sorry no picture).
Router table with the bit sticking up say 1/2-3/4", turn on the router, take some wax (candle wax will do) and plunge the wax down onto the bit, not all the way down, just 1/4-3/8" is enough. Now take the glued body to the router table say top down. Cut the side excess off with the bit. The wax acts as a natural bearing and fills the cutter so it doesn't cut into the body. The coolest part of this set up is that you won't get blowout, you see the bit is supported on both sides and won't blow out the top wood.
I don't know If I've done this method justice or not, wish Mario was here to show pics and explain.
Once I get back into the shop, I'll use this to trim the excess on the next guitar and will take pics and try to explain the process better.
PostPosted: Mon May 14, 2007 4:11 am
Dzouki saw and a fine file.
Slow and tedious. But at least theres no danger of messing up.
To be honest if I had a lam trimmer I'd use it !!!!
Richard
Richard
PostPosted: Mon May 14, 2007 5:40 am
I use a small plane, then go to my spindle sander. Routers scare me
PostPosted: Mon May 14, 2007 7:18 am
How does this jig follow a sloping back and provide a perpendicular cut? Does it pivot about the horizontal axis?
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Mon May 14, 2007 7:28 am
Flush trim bit in a hand held router; I try to take small bites in the "trouble areas" to avoid splitting off chunks of wood, so far no big uh-ohs. You have to pay attention though.
PostPosted: Mon May 14, 2007 4:31 pm
Flush-trim bit in a router table. If you pay attention to grain orientation,
as everyone has mentioned above, it is just about impossible to damage
your guitar.
Peace Out,
Simon
PostPosted: Mon May 14, 2007 9:39 pm
I use a flush trim in a dedicated visa points router - its too cheap to use for anything else !!!!
My method is slightly different from others though - I route into the waist areas first - straight in, then chew a bit to that from each bout, say an inch. Now you route all the edges downgrain, whether its climb or not - so, from the top of each bout into the waist, then top of each bout to the blocks. Taking out the waist area first means there is nothing there for the bit to grab and tear as it bottoms out in there. Blowout doesnt happen.
PostPosted: Mon May 14, 2007 11:35 pm
Last guitar, I used a robo-sander in my drill press--like a flush trim bit. It's slow but safe, very little chance of a major screw-up.
PostPosted: Wed May 16, 2007 11:13 pm
I've done a few with the Robo-sander, but I find it tends to burn the sleeve because such a tiny area is in contact so it's very easy to go a bit fast and overwork it.
If you follow the Stewmac procedure you'll get pretty much guaranteed results in just a few minutes.
Richard
http://www.guitarmaker.com
PostPosted: Thu May 17, 2007 12:16 am
I use a lam trimmer with a flush trim bit. Haven't had any problems doing it that way so far.
