It is currently Thu Jul 17, 2025 8:01 pm
PostPosted: Sun May 27, 2007 2:14 pm
I have a Performax 16/32 and I'm hoping there are better choices in sandpaper for it than buying their stuff. Any suggestions for me?
Thanks!
PostPosted: Sun May 27, 2007 2:20 pm
I use Klingspor (made in Germany, I think) in 3" wide velcro backed rolls.
Klingspor
PostPosted: Sun May 27, 2007 2:24 pm
i have been very lucky getting bulk rolls on ebay quite cheaply.
PostPosted: Sun May 27, 2007 8:50 pm
Steve try here.
http://www.onlineindustrialsupply.com/
PostPosted: Sun May 27, 2007 10:50 pm
First name: Jim
Last Name: Kirby
What Bobc said. Look for the 150' rolls. Just save one of your original 16/32 papers and use it as a template to cut new ones.
Their prices on regular size sheets is quite reasonable too (Mirka brand - I like it so far).
Velcro?
Jim
Jim Kirby
kirby@udel.edu
PostPosted: Sun May 27, 2007 11:34 pm
[QUOTE=Hesh1956] Ron why velcro backed paper? I need a source for paper too for my 10-20 but it does not use velcro backed paper.[/QUOTE]
Klingspor sells every kind of sandpaper. I use velcro backed because it is so quick and easy to change grades or replace. Also, the paper doesn't creep around on the drum.
PostPosted: Sun May 27, 2007 11:54 pm
Hesh, here is a link to the place for buying a hook & loop conversion roll. It is a self stick material to wrap your drum, then the velcro backed paper is just stuck on. I still tape the ends of the roll to be sure it doesn't come loose. I really like it.
Velcro conversion for drum sander
PostPosted: Mon May 28, 2007 12:33 am
First name: Cecil Wayne
Last Name: Carroll
City: West plains
State: Missouri
Zip/Postal Code: 65775
Thanks Ron,
I am in the middle of building mine and was looking for a source for hook and loop systems. Your timing could'nt have been better.
Cecil
PostPosted: Mon May 28, 2007 12:39 am
I don't know if you noticed, but Stockroom Supply was also having a sale on ROS hook & loop paper for finishing up to 3000 grit.  It was half price.  They also sell the parts for drum sanders - pillow blocks, balanced pulleys, polycarbonate drums that are static free, all can be used to make either top cutting sander or bottom cutting sander that produces less heat.  I have seen the bottom cutting sander in action, and it is pretty impressive.  No dust at all in the air even with no dust collector.
PostPosted: Mon May 28, 2007 2:13 am
Steve, I've been using these guys with good results.
Online Industrial
PostPosted: Tue May 29, 2007 2:59 am
Online industrial has good pricing for there rolls. Just wish I had a local Canadian source.
What I do is go to the local tool store and buy a 6x96 belt for a belt sander. Cut it and wrap it on my drum. Costs me $17 per belt and I get a little bit left over to use for other sanding needs.
PostPosted: Tue May 29, 2007 3:02 am
Gee, you guys sure got some good woodworking supply stores down there in the US, consider yourself lucky.
PostPosted: Tue May 29, 2007 4:20 am
Actually, Stockroom Supply is in Canada.  Lowbanks, ON
PostPosted: Tue May 29, 2007 5:06 am
Hey Thanks Waddy, haven't seen these guys before.
You learn something new everyday, now if I could only remember what I learned yesterday
PostPosted: Tue May 29, 2007 5:39 am
They used to make the Woodworking Show Circuit, but I haven't seen them recently.  I guess they got their products pretty well recognized.  Their Drum Sander is unbelievable. No burning, no buildup, no adjusting, and no dust in the air.  It is, however, multiple pass, and you don't get to set the thickness since the work is pushed over the top of the drum.
PostPosted: Tue May 29, 2007 10:55 am
Any problems with the hook and look "giving" a bit and not giving an even cut across the wood?
-j.
-jack handy
PostPosted: Tue May 29, 2007 11:05 am
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
J I think I`ve had that problem.It wants to leave a little ridge because of the way it attaches.As far as I can tell the sander is set up as close as I can get it .           ; James
James W Bolan
Nashville Tennessee
PostPosted: Tue May 29, 2007 2:59 pm
Haven't had that problem with mine when working on a guitar part (thicknessing). Trying to hog off too much at once could do that, I suppose. I thickness top, back, and sides, and my headstock, and it is nice and flat.
