It is currently Fri Sep 19, 2025 1:08 am
PostPosted: Tue Jun 19, 2007 4:27 am
First name: Louis
Last Name: Freilicher
City: Belchertown
State: MA
Zip/Postal Code: 01007
Hello OLFers. I posted a little tutorial on turning pins some time ago. Well I finally got the bugs worked out of the cutters and have been turning the pins in wood with some degree of success! (Only a few explode!)
I'm working on the bridge pin cutter and when I gets some sets together maybe I’ll throw a few up on the luthiers auctions site. Let me know what you think.
Thanks for looking.
Louis
- Louis Freilicher
PostPosted: Tue Jun 19, 2007 8:20 am
Nice! I think I like the one with the more domed top better; or, is that just an illusion?
PostPosted: Tue Jun 19, 2007 1:51 pm
First name: Ringo
Nice. Is that brass tubing around the abalone?
PostPosted: Tue Jun 19, 2007 2:25 pm
First name: Louis
City: Belchertown
State: MA
Thanks guys.
Carlton one of the pins does have more of a dome to the top. I think I like that one better myself.
Lex, yes the abalone is press fit into a brass tube and the two are inlayed as one piece, then leveled as usual. Almost the French eye inlay you see on some violin pegs.
Louis
- Louis Freilicher
PostPosted: Tue Jun 19, 2007 2:37 pm
Mighty nice looking pins! Let us know when you decide to sell a few sets
PostPosted: Tue Jun 19, 2007 3:26 pm
Beautiful work Louis,
They are very nice as is but I bet if you could some how incorporate an end pin jack into that type of organic look they would be enormously popular.
I know there is a vendor doing this already using a taper friction to retro fit vintage guitars. But if one could come up with an attractive button which features some wood into the design, is fitted via a straight 1/2" hole in the tail block of the guitar ala K&K, LR Baggs etc and accepts a standard 1/4" jack....wow.
Just thinking out loud
PostPosted: Wed Jun 20, 2007 3:55 am
First name: Louis
City: Belchertown
State: MA
Thanks all.
Kim, that sounds like a great idea. I know Barcus Berry (sp?) used to make an endpin jack that would fit a standard reamed endpin hole but had a small 1/8" connection. That way you could put a sound hole pickup in you 34' D-28 and not have to ream the endpin hole out at all!
In reality they preserved the vintage look but were a bit floppy in functionality as a jack.
Maybe a wooden strap button with a treaded brass insert that would fit the standard 1/4" endpin jack would be the way to go? Now, get back to the R&D department.
Louis
- Louis Freilicher
