It is currently Sun May 25, 2025 10:40 pm
PostPosted: Mon Aug 06, 2007 1:32 am
I have been meaning to put this up for while. I found the process of laying the purfling a bit tricky and wondered whether there was an alternative approach. I had been messing around with a homemade vacuum and thought that I might be able to form the rosette grouping of purfling veneers in the round.
The process entailed wrapping the veneers, polycarbonazte sheet, vinyl vacuum sheet around a pipe and applying the vacuum for about an hour. The formed rosette purfling was then sliced using the fret slotting saw to produce 0.080"/2mm slices.
regards
Tim
PostPosted: Tue Aug 07, 2007 1:32 am
I had an opportunity to take a couple of close up images. I will put up a few images of my vacuum form tomorrow
PostPosted: Tue Aug 07, 2007 1:46 am
Tim that worked very nicely.
Look forward to the pics of the vac form.
I'm stuck on individual lines from Martin.
This is intriguing however.
Thanks for sharing.
Question: How did you saw them? TIA
PostPosted: Tue Aug 07, 2007 1:47 am
Tim, what do you slice them with? I've had some bad luck using a bandsaw on cylindrical stuff like that.
PostPosted: Tue Aug 07, 2007 1:58 am
[QUOTE=Pwoolson]Tim, what do you slice them with? I've had some bad luck using a bandsaw on cylindrical stuff like that. [/QUOTE]
I believe he said he uses a fret slotting saw blade.
PostPosted: Tue Aug 07, 2007 2:02 am
Thanks Waddy.
That is correct however I should qualify it by saying that I tape up the lamination end to complete the circle and then place them in a cradle just above the fret slotting table saw blade and revolve the form to slice the rosette laminations. I will make sure I post a few pictures tomorrow.
Tim
