It is currently Fri Jul 25, 2025 7:19 pm
PostPosted: Mon Aug 13, 2007 8:23 am
Hi guys, I am ready to brace the top of my L-0. I have an old vacum frame
that was used in screen printing. I want to convert it to a press to glue
my braces. What material is used for the top. Rubber, plastic. I know
some people use a polyurothane of some kind. Some of it looks foam like
and thick. Where do I get whatever I should use. How thick? If you have
any knowledge on vacum bracing please send it my way...thanks
PostPosted: Mon Aug 13, 2007 8:29 am
LMI sells the membrane
PostPosted: Mon Aug 13, 2007 9:27 am
There are lots of vacuum clamping sources out there.
The industrial supply houses also have natural latex and vinyl membrane by the foot. (MCI, McMaster Carr, etc)
I'd lean towards natural latex if I were you.
PostPosted: Mon Aug 13, 2007 9:47 am
Last Name: Garrish
The stuff LMI sells is just 1/32" neoprene sheet. You can probably get your local rubber supply place to give you a piece for a few bucks. I use the same stuff on my vacuum clamps.
Bob Garrish
PostPosted: Mon Aug 13, 2007 10:29 am
First name: Dean
Last Name: Bayles
City: Leucadia
go to joewoodworker.com, he's got everything you need.
Dean
