It is currently Thu May 29, 2025 12:50 pm
PostPosted: Fri Aug 31, 2007 3:32 am
Benjamin Zander, Conductor of the Boston Phil and motivational speaker, instructs people to "always remember rule #6."  Rule #6 is "don't take yourself so D*** seriously.
I've heard other highly successful people say similar things, like "if you're going to make it in this business kid, you gotta be able to laugh at yourself"
I live by that advice (not that I consider myself highly successful.) Especially now.
Can anyone spot the reason I'm laughing at myself?  It has nothing to do with any of the clutter or tools on the work bench and lies entirely with the  work board and guitar sitting under it.
I closed the box last night.  I've never used a work board before.
When I took the clamps off this morning, I discovered my problem.
please tell me I'm not the first to make this mistake!
Enjoy the game,
PostPosted: Fri Aug 31, 2007 3:38 am
Hmmm. Did the board get glued to your top? Unless it is that I don't have a clue. I am not using a board for my build.
Christian
PostPosted: Fri Aug 31, 2007 3:39 am
First name: Josh
Last Name: French
City: Houston
You've got the soundboard clamped to the workboard and no way to unclamp it because it unclamps from the inside?
Instagram: @jfrenchluthier
PostPosted: Fri Aug 31, 2007 3:44 am
[QUOTE=jfrench]You've got the soundboard clamped to the workboard and no way to unclamp it because it unclamps from the inside?[/QUOTE]
And the winner is,
Mr. French!
Somehow I've never seen vice-grips in the list of tools needed for luthiers.
PostPosted: Fri Aug 31, 2007 3:55 am
Dave, good for laugh. I could almost hear the "Ta Da!" playing during the last photo. Good recovery.
PostPosted: Fri Aug 31, 2007 3:56 am
Ben Zander is one of my favorites. Truly an inspriring guy.
PostPosted: Fri Aug 31, 2007 4:01 am
First name: Josh
Last Name: French
City: Houston
Great! I was going to suggest drilling through the bolt... glad you got it taken care of!
PostPosted: Fri Aug 31, 2007 4:02 am
First name: Josh
Last Name: French
City: Houston
Oh, I am also proud to say my guess wasn't the result of experience!
PostPosted: Fri Aug 31, 2007 4:07 am
I don't use a board or build classicals, but I did see someone do this. and they admitted it on a forum.
So, what's the answer for next time?
PostPosted: Fri Aug 31, 2007 4:18 am
It WAS the soundboard clamp.
And We're all winners, because if you read this, then it probably won't happen to you.  Handy is that whole concept of learning from other's mistakes.
PostPosted: Fri Aug 31, 2007 4:26 am
Hah .. Bill Moll has you all beat ... he asked once if anyone knew how to get internal spreaders out thru F holes !!!
You guessed it, he had to take off the back.
PostPosted: Fri Aug 31, 2007 7:11 am
That's good.  Now that I've seen it, maybe I can keep from doing it.
PostPosted: Fri Aug 31, 2007 12:52 pm
You know, a vacuum solera might be fantastic. You could build in the arch of the top, have perfect stability with no clamps in the way, etc., etc.
PostPosted: Sat Sep 01, 2007 12:17 am
Good that you can laugh at yourself Dave,instead of smashing it against the wall. Glad you got the bolt out without having to drill or ruin your workboard. I'll bet this has happened to a lot of us .
PostPosted: Sat Sep 01, 2007 12:43 am
My old Solera was ripe for this problem.....the thumbscrew which held the soundboard in place had to be removed before the back went on.
Thankfully I always remembered to do it....however, now that I'm getting older (and revamping my fixturing) I'm building a new Solera which will be "foolproof" (that would be me) as far as getting the top
support out. (hint: don't make this support too long either.....) <GRIN>
PostPosted: Sat Sep 01, 2007 1:21 am
I've done something similar before... boxed up a body and left both waist
length and lower bout spreaders in. They don't fit back out through the
shoundhole, but after a couple hours I managed to get them out through a
end pin hole... I'm glad I used quarter inch rods that fit out through the
hole....
