It is currently Sat Aug 02, 2025 5:49 am
PostPosted: Fri Sep 28, 2007 2:28 pm
Is there a relationship between fretboard radius and playability?
I have a possible steel string client wondering about this. I have only built with a 16" radius.
Would a 60 year old with large hands and trouble holding down barre chords be better off with more curvature or a flat fretboard?
PostPosted: Fri Sep 28, 2007 9:52 pm
BUMP
Good question Steve, one for the accomplished Player/Builder to answer.
PostPosted: Fri Sep 28, 2007 10:57 pm
The theory is that a smaller radius should make it easier to hold down
barre chords.  Vintage Telecasters (for example) have a 7-1/4"
radius, and I've heard a few repair guys swear they've seen a few with
a 6" radius; that's the smallest I've heard of.
IMO...being 60 I'll venture that your guy is battling arthritis with
the barre chords.  Jumbo frets might help there, also downtuning
to Eb.
PostPosted: Fri Sep 28, 2007 11:03 pm
First name: Glenn
Last Name: LaSalle
City: Saint Petersburg
I think it also depends on the music you play.  I play fingerstyle guitar, and I do not like small radius fretboards.if you bend strings at all, a flatter FB will be easier.
Glenn
PostPosted: Sat Sep 29, 2007 12:31 am
My personal preference is a 12" radius board. Barr chords are a little easier to fret and it just "feels" better to me. Not as comfortable to bend as a flatter radius board, though.
PostPosted: Sat Sep 29, 2007 1:50 am
First name: Rick
Last Name: Hubka
City: Chemainus
State: BC
Zip/Postal Code: V0R 1K1
Can someone please chime in here on the playability advantages of a compound radius?  I've heard they are better and don't know why
Rick Hubka
Chemainus BC Canada
PostPosted: Sat Sep 29, 2007 2:46 am
I've built with both constant Radii and compound radii on acoustic guitars. I don't think it matters on an acoustic instrument. I currently build with a 16" radius.
The purpose of the compound radii is to prevent "fretting out" when bend strings. You can get a lot more bend on an electric guitar than an acoustic (well me anyway)and I've never fretted out or known anyone whose fretted out on an acoustic guitar, so I just build a constant radius now.
Hope that helps.
PostPosted: Sat Sep 29, 2007 4:42 am
I use a compound radius (although I'm contemplating switching) in theory it
makes barre chords easier closer to the nut and yet does not fret out when
bending up the neck. In practice I don't see much of a difference.
PostPosted: Sat Sep 29, 2007 4:59 am
For what it may be worth, I really think it depends on the player as much as the instrument. I've got a J-45 with a 12" radius fingerboard that is amazing. I've also got a D-28 spec'd with a 16" radius that actually measures out closer to 20", even though the board hasn't been touched or refretted since it left the factory in 1985. I can tell a difference, but can't really say one is better than the other. If I'm not mistaken, doesn't Gretsch build with a 12" radius as well? All that said, I think dead flat belongs only on classical guitars, and even that is debatable to me. I would think either 16" or 12" for steel string and both would be equally valid. In the long run, I don't know that using one radius over the other would make much of a difference, at least to me... to someone else, it might though.
PostPosted: Sat Sep 29, 2007 5:40 am
City: Keene
The real purpose of a compound radius is to maintain relatively uniform
action on a tapered fretboard. A fret board that is the same width from nut
all the way up should have a constant radius. Think of it as the side of a
cylinder. However, most fretboards are taperd. The nut width is smaller than
width at 12 fret. A compound radius is used in this case. Think of it as the
side of a cone. If you use a constant radius on a tapered fretboard, the
strings will get higher of the frets the farther you move up the fretboard.
PostPosted: Sat Sep 29, 2007 9:23 am
First name: Rick
Last Name: Hubka
City: Chemainus
State: BC
Thanks for the compound radius info guys.  It makes sense now.
I can see how some might compensate and adjust the string height at the saddle and others will use a compound radius.  Although doing both would seem like the ideal solution.
I can also see how fret leveling or re-fretting would be much more difficult with a compound radius.
The perfectionist in me says "go compound".  The sensible part of me says use one radius and "KISS" on the fretboard.  In case there's one out there that doesn't know what "KISS" means...  It's "Keep It Simple Stupid".
Thanks again
Rick Hubka
Chemainus BC Canada
PostPosted: Sat Sep 29, 2007 10:21 am
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
I prefer a 12" radius.Much easier to play than a flatter 16".         &n bsp; James       &nb sp;
James W Bolan
Nashville Tennessee
PostPosted: Sat Sep 29, 2007 11:04 am
My understanding of a compound radius is that, given the fact that the neck and strings taper, they form a curve closer to a conical section than a cylindrical section.  Therefore, a compound radius (conical section) allows the fb to be more parallel to the strings all the way up the neck allowing better action.
In practice, it is more complex than that but in my experience, changing from a simple to a compound radius allowed me to get better action.  That said, some people achieve similar results by leveling the board and/or frets in a path parallel to the strings, as opposed to parallel to the center line of the neck. Same basic idea.
http://www.chassonguitars.com
PostPosted: Sat Sep 29, 2007 12:53 pm
I am almost understanding this. I have one question though, if someone would be kind enough to answer:
What is the difference in string height at the 12th fret between a standard 16" radiused fingerboard and a fingerboard that is compound radiused?
PostPosted: Sat Sep 29, 2007 1:26 pm
J, sorry, I must have missed your post and pretty much repeated what you said.
Rick, as for fretting a compound board, it's not any more difficult.  If you hammer frets, it is exactly the same.  For pressing frets, I use a caul that matches the tighter radius and go back and lightly hammer the whole board to make sure all frets are well seated.
