It is currently Tue Sep 16, 2025 7:52 pm
PostPosted: Tue Oct 09, 2007 9:25 am
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
I`d like to profile the sides before bending as in Colin`s tutorial.I want to profile the top side first and then the back getting my taper end to end according to the depth at each end allowing for top and back thickness and maybe a little extra ,maybe 3/16 or so for sanding later.Am I thinking correctly or what? I just always need a little guidance.
                            James
James W Bolan
Nashville Tennessee
PostPosted: Tue Oct 09, 2007 9:58 am
i side profiled this way and it worked great. only thing i did somewhat diff was i first drew a straight line on piece of construction paper the length of the side. at each end drew perpendicular (90 degree) line to the length of tail and neck then connected those for the taper of the back. then placed the tape with profile drawn on it to the corners. cut the shape out of the paper and did like Colin shows. worked good . just cut the wood a little bigger. ive only done this once and am on my 2nd built so take this advice knowing that.
PostPosted: Tue Oct 09, 2007 10:39 am
Do you have the link for this?
 I need to get an even side profile with my box, but its already bent, any basic 'shortcut' advice.
PostPosted: Tue Oct 09, 2007 10:58 am
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
If it`s already bent,just stick it in the appropriate radius dish ,scribe it ,plane it close,and then sand it till it fits nice and tight.This is the way I`ve done it in the past.I`m trying to eliminate a lot of hand planing.The tutorial page has Colin`s side profiling method I`m going to try .
                James
James W Bolan
Nashville Tennessee
PostPosted: Tue Oct 09, 2007 12:31 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Oops Todd`s right.Glue the end blocks in first then sand the profile in the dish.That`s exactly the way I`ve done it.
              James
James W Bolan
Nashville Tennessee
PostPosted: Tue Oct 09, 2007 12:32 pm
Most explanations to profiling I have found does not really match the dome intersection but rather account for general taper of the back from LB to UB. I profile the back pre-bend but leave the top flat till the blocks are glued up then I sand the actual dome into the side. install the linings and re sand the dome shape into the linings.
I have yet to see a profile method that accounts for the waist being the highest point of intersection with the dome. Profiling the back with the basic taper down save a good bit of sanding time. But if you are like me and have the dome fit perfect with the rim and linings the top is just as easy to sand down and not pre-profile
PostPosted: Tue Oct 09, 2007 12:39 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
It is true Michael since the top isn`t really tapered just domed it`s pretty easy to sand after installing the blocks,as not a lot of material is being removed as is with the back.Plus it will give me a little more wiggle room.
                   james
James W Bolan
Nashville Tennessee
PostPosted: Tue Oct 09, 2007 9:03 pm
I too profile the back but leave the top flat before bending, just because this makes it easier to ensure the slat is square in the bender.
When the sides are bent and joined by the head and tail blocks then I'll use the stiff paper profile with both the back and top profiles on it, taped to the sides and draw in the profile for the top, plane to the line.
Then the linings are glued in and back and top dish sanded to bring the linings to the right shape. This only takes a minimum of sanding.
PostPosted: Wed Oct 10, 2007 4:49 am
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
I've done this on my CNC....I model the side as I want it and then I can "unroll it" in CAD. I set it up specifically for the shape I use and the taper that I want..then just a matter of cutting it out. Works pretty good...!
http://www.PeakeGuitars.com
PostPosted: Wed Oct 10, 2007 5:13 am
How did you unroll your mesh or 3d solid to get it into a flat view?
PostPosted: Wed Oct 10, 2007 11:13 am
First name: Trevor
Last Name: Lewis
City: Crownsville
I use Rhino, but you can probably do something similar in solid modeling apps such as SolidWorks using the sheet metal functions. I've never used many of the sheet metal functions (sheet metal is for wusses! ) but I would think that functionality is in there somewhere.
In Rhino you use the "unrollsrf" command.
I start by modeling the sides as they exist; bent and tapered. I really just model the outside surface...I am not actually creating a solid model of the sides. Then you just run the unrollsrf command and Rhino unrolls it for you. Seems to work pretty well..!
Users browsing this forum: No registered users and 41 guests
