It is currently Sat Jun 14, 2025 10:30 am
Post new topic Reply to topic  [ 83 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Sat Oct 13, 2007 1:56 pm
   UPDATE - See post with photos part way down page 2 for photos of new listings and update as of 6 PM Friday
Well, here is my stuff. Sharing my extras. On some items, I may be able to scrounge up a few more of, but please keep all requests in this topic.
First the Free Stuff: Ebony Offcut Bundles
I resaw a lot of ebony and end up with bunches of offcuts. These are bundles of about 2 pounds that will fit in a Priority Mail Flat Rate Envelope. Most are +/_ 1/4" or so thick with at least one thicker piece in each bundle. Rosette stock, inlay, maybe even a small bridge blank. $5.25 to cover the postage and paypal fees. I have 6 bundles made up. Since these are going by mail, US shipping only. I can do more of these, so available
________________________________________________________
Curly Burr Oak Back and Side Sets
This is some of the nicest curly Burr (a species of white) Oak I have seen. These are two sister sets, sanded. Backs 26" long, 11" at the wide end and 6" at the narrow end. Cut from a huge 275 year old oak that had to be taken down to prevent it falling on a house. Burr Oak is a bit less porous than regular White Oak. These sets have both the curl and a nice ray figure.
2 sets available - $65 each Both sold, see update for 2 more available sets
A closeup of the figure
Note: All backs and tops show a standard dreadnought outline for size reference. The right hand side and back pieces have been wet with naptha to show the color and grain.
Fully Quartersawn Cocobolo Back and Side Sets
These are identical sister sets, so I am only showing one photo. Very well quartersawn sets, Nicaraguan hurricane blowdown. Backs 8 1/2 by 22, sides 5 by 34, sanded. The color will even out with a little more exposure to light.
2 sets available - $175 each Both sold
Mostly Quartersawn Cocobolo Back and Side Sets
These are 2 sister sets, well QS in the center 2/3. Backs 8 3/8 by 22 and sides 5 1/8 by 34, sanded. Lots of color, reds, black, and browns, will darken under finish and sides will oxidize to match the back colors. Because the grain varies in the outer part of the backs, I will show both photos.
2 sets available - $145 each Both sold, see update for 2 additional sets
Quartersawn Honduran Mahogany Neck Blanks
Very well QS and straight grained, 3 1/8 by 15/16 by 31 for scarfed peghead necks. These 6 are consecutive sawn blanks from 12/4 perfectly flatsawn stock to yield QS blanks.
6 avaible - $20 each All sold
I just dug around in the basement of the shop and found a dozen off quarter neck blanks. These are the same high quality wood and same size as those above, just sawn closer to the edges of the slabs where the growth rings are starting to curve. These have grain ranging from 45 to 60 degrees off the face. Rip them down the center, flip one half and glue in a center strip, and you are ready to go. I will offer these for $12.50 each, high grade Honduran mahogany. 4 sold, 8 still available
Wood Binding Strips - Mix or Match
These are 1/4" wide by approx 0.80" thick, and from 31 to 34" long. The following list are the species and numbers of each available, along with a few comments.
you can ignore the numbers, I have more of all species
African Satinwood - 2 doz., nice flame figure
Balsamo, light - 3 doz., med to light brown, med dense
Balsamo, dark - 2 doz., darker brown and a bit harder
Bloodwod - 2 doz. 1 doz. Sold, 1 doz. left
Bocote - 4 doz., nice figure
Cocobolo Rosewood - 5 doz.
Goncalo Alves, regular - 4 doz., russet w/black stripings, very hard
Goncalo Alves, dark - 4 doz., med. to dark brown with black markings
Katalox/Wamara - 4 doz., dark purplish brown, very hard
Lacewood - 2 doz.
Central American Laurel - 4 doz., lighter grayish tan with darker markings, nice ray pattern, med. hard
Macacauba - 4 doz., mauve/brown
Flamed Red Maple - 4 doz., almost white sapwood, figure shows best under finish
Flamed Myrtle - 3 doz.
Padauk - 2 doz.
Purpleheart - 4 doz.
Red Heart - 3 doz., these end up orange/brown
Peruvian Walnut - 5 doz., rich, uniform chocolate brown
Wenge - 3 doz., nicely QS
Zebrawood - 1 doz.
All of the above are $28/doz.
Ebony - 12 doz.,these will mostly have a few light streaks, helps to tell they are not plastic 2 doz. sold, 10 doz. left
Med. Figured Koa - 4 doz., nicely QS
These 2 are $36/doz.
White Spruce Guitar Soundboards
In Northern Minnesota white spruce, Picea glauca, grows as a pure strain, not hybridized with anything else. I cut tops for my guitars from the few choice logs that I can find. This wood is almost identical in tone to Adirondack, but is whiter in color and has less visible grain lines. I have more of this than I can ever build with, so I am offering three tops, one from each of my best logs. These are all of higher quality wood than most of the Adirondack I have seen available. These are all sanded to approx .165 - .170". Very stiff both along and across the grain.
Top 02, from log 02 - $45 Sold
This top has some hard grain lines which are a cosmetic issue. About 20 grains/inch at the center and averaging about 10 for most of the width. (note: I checked and the dark spot in the left lower bout area is a dirt speck, gone)
Top 00, from log 00 - $55 Sold, I have a sister set that I will make available, but it is spoken for
Except for a few darker grain lines at the very outer edge, this top is almost pure white. Mostly a uniform 10 to 12 grains/inch, wider at the outer edge.
Top 03, from log 03 - $65 sold
This almost pure white top is from my best log (the one I use the most). It has a fairly uniform 15 to 20 grains/inch. The spike knot stops dead, well outside the pattern (shows how well QS the top is). For some reason the color looks a bit irregular in the photo - it is not that way.
Giraffe Bone Nut Blanks
I have more of these than I will use. This is some of the most awesome bone there is, very thick walled and dense. These are rough blanks, a heavy 1/4" thick by about 2 1/4" long.
6 available - $6 each Sold
Last Item; One-of-a-kind Master grade Cocobolo Back and Side Set
Ok, I know you don't see it graded this way, but this is a very special set that I don't envision myself ever building with. The backs and sides came from the same 22" diameter (all heartwood) old growth cocobolo log that I bought about 5 years ago. Because it was 51" long, I cut it all into back billets (I had similar side wood) except for one slab that was too narrow due to a center crack in the log. Most of this went into harp guitar sides, except for this one set that I had to cut down due to a bad spot at the end.
This is an oversize set, backs 9 by 22 and sides 5 3/8 by 36. These are perfect 90 degree quartersawn for the full width and have very fine straight grain. Very rich color and a perfect side and back match. I would not be afraid to say that this is the very best traditional grained cocobolo set you will find. There are a couple of dark stains on the inside face of one of the sides along one edge, but these will be profiled out.
I have only one set, period at $225 Sold
And here is the log and how this set was cut.
So that's my stuff. Thanks for looking.
I will take Paypal, money orders, or checks and will charge actual shipping costs. Be advised that our local hardware (the UPS drop point) charges an extra $2.50 fee. And, yes, for those outside of the US, I am happy to ship USPS anywhere.
I will be mostly busy during the day, but will update in the evenings.
Grant Goltz UPDATE - 6 PM Friday, see photos on page 2
PostPosted: Mon Oct 15, 2007 1:05 am
Grant, I would like to buy 3 of your mahogany neck blanks, set 1 of the mostly quartered Coco and a dozen bloodwood binding.
PostPosted: Mon Oct 15, 2007 1:06 am
Last Name: Abercrombie
Grant-
I'd like to buy:
Top 00 and Top 03 and the Cocobolo Master set.
PostPosted: Mon Oct 15, 2007 1:10 am
HI Grant,
I would like 2 doz. of the Cocobolo bindings at $28.00/doz.
Max Bishop
Brighton, Michigan
Max Bishop
Brighton, Michigan
PostPosted: Mon Oct 15, 2007 1:12 am
Grant,
I would like one of the QS Colobola sets at $175.
GregH
Fot Wuth
PostPosted: Mon Oct 15, 2007 1:17 am
Grant,
I'll take the burr oak #2 set.
tim...
I'd like to buy the other $175 coco set and one of the $145 ones
PostPosted: Mon Oct 15, 2007 1:23 am
I'd like the 00 white spruce top.
Ken Franklin
clumsy yet persistent
PostPosted: Mon Oct 15, 2007 1:25 am
Last Name: Walden
City: Bartlesville
State: Oklahoma
Zip/Postal Code: 74006
I'll take the left over burrr oak and a bag of eb off cuts!
Steve Walden
Aspiring Builder,
Bartlesville, OK
PostPosted: Mon Oct 15, 2007 1:28 am
Ken, the top number 00 is gone, just the 02 left.
Grant
PostPosted: Mon Oct 15, 2007 1:36 am
First name: Gary
Last Name: Lee
Grant,
I would like the 3 remaining neck blanks. Thanks.
PostPosted: Mon Oct 15, 2007 2:00 am
Grant, do you happen to have a sister set to the 00?
Ken Franklin
PostPosted: Mon Oct 15, 2007 2:03 am
Hey Grant,
I would be interested in some more white spruce if you have any more to part with. I don't mind making wings to fill out the lower bout if there are some pretty but narrow tops on the pile.
Burton
Burton
Brookline, MA.
PostPosted: Mon Oct 15, 2007 2:21 am
Grant,
Could I get one of the ebony offcut packs and 2 of the off-quarter neck blanks.
thanks,
chris
Chris Oliver
Infinity Luthiers
...in the shop.
live every minute...
PostPosted: Mon Oct 15, 2007 6:08 am
Check my listing above. I just got home a few minutes ago and updated the status of everything.
Ken, I have a sister set to the 00 log white spruce top, so consider it yours. I will also dig out a few more of the white spruce tops.
I put up 6 more of the quartersawn Honduran mahogany neck blanks.
I will dig out another curly oak set or two, and some more cocobolo sets. Check back later, I will have to take photos and such.
Thanks everybody.
Grant
PostPosted: Mon Oct 15, 2007 7:28 am
Grant
I'll take all of the giraffe bone nuts.
Bob
Bob Connor
Geelong, Australia
PostPosted: Mon Oct 15, 2007 8:18 am
Hey Grant, I only wanted one dozen of the Bloodwood bindings.  Is that OK?  I noticed that you marked it all sold, but didn't see anyone else asking for it.  I think Max B. wanted 2 dozen of the Cocobolo.
PostPosted: Mon Oct 15, 2007 9:26 am
Grant,
I would like 2 dozen of the ebony bindings.
Thank you,
Greg
GregH
Fot Wuth
PostPosted: Mon Oct 15, 2007 12:41 pm
Sorry about that, Waddy. One dozen is what I have written down, just screwed up editing the post, did it in a hurry.
Looks like I am about sold out of backs and sides and tops and 9 more days to go. So dug around in the shop tonight. Found some quartersawn curly cocobolo backs that have minor blems or small crack repairs. Otherwise top notch wood. I need to match some sides and do the photos. There will be 3 sets at $125 each normally $185 sets. I will also have another of the fully quartersawn coco sets like in the original listing, again at $175. I also have one more curly oak set identical to set 2 above, again at $65, and I will put up another set with backs from another billet for $55.
I also went down to my wood shed and dug out another white spruce top billet that I cut a couple of years ago. This one perfectly white and hand split with zero runout, something very rare in eastern spruce. Here is the back face cleaned up on the planer. The red marks outline the remnants of the split face.
And here is the other face. very uniform white color and the growth rings are an even 12/inch across the whole face.
And so you can see the growth rings, here is the end of the billet.
I resawed this into 5 tops and will offer 4 here for $75 each, when i sanded them today, the last one had a stain at one end so i won't be selling it. (yes, I did save a couple of billets of this for myself). I will post a photo tomorrow, but if you want to buy based on the above photos now, go ahead. All of these tops are identical and 8 1/2" wide. Call these Billet 6 white spruce tops. All 4 sold
Here is the latest update stuff. First a photo of the white spruce sets from the above billet. They all look absolutely identical, so I will post one photo to save space. These are $75 each and all are sold.
Grant
next a White Spruce Classical size top
Grant
This has 12 to about 10 nice even grains/inch. Lt will make a 15 inch top classical or OM size, Ramirez classical outline drawn. This has some light gray staining at the outer edge, so I have dropped the price to $25. A very light "burst" would totally hide the stain. Sold
OK, I dug out a variety of cocobolo. So I am going to list it all now. This will probably be it for the coco for this swap.
First the $125 sets
These are from a curly coco log that I resawed about 4 years ago. Here are 3 sets that would be $175 sets if they did not have minor "issues". The sides on these sets are all 5 by 32 1/2 and are consecutive cut from the same fully quartersawn billet.
Curly set 1 sold
This set has a tiny tight spike knot and knot shadow "curl" at waist. Also a small check that extends about 3/8" into the waist on a dread outline. A very slightly narrower waist or fat purfling would cover it.
Curly set 2 Sold
This set has a similar knot/curl at the waist as set 1. Otherwise OK. I did repair a short crack at the top end with CA 2 years ago, it seems fine.
Curly set 3
This set is OK except for a crack at the outer edge of the lower bout for a dread size. It will make a 15" body just fine. Or you could try a center backstrip and wide purfling for a bigger body.
Next a Budget Coco set
This set has backs almost QS in center running to flatsawn at outer edge. Good solid wood, sides 5 by 32 1/2, backs 8 1/2. available, price reduced to $95
2 more Mostly Quartersawn sets Reduced to $135 each
Backs are sisters from the same billet. Backs 8 1/2. These will oxidize and darken and even out in color.
Coco set 5 Available
Sides 5 1/4 by 33.
Coco set 6 Available
Backs 5 1/4 by 34
next 2 more Fully Quartersawn sets
These have backs from the same billet as the "Master Grade" set I offered in the first post. Extra wide, nice black lines and rich color, fine grained. Sides are sisters from a nicely matching billet, 5 by 34. $175 each
Quartersawn Coco 3 Sold
Quartersawn Coco4 Sold
next 3 more sets of Curly Burr Oak
First an exact sister set to set 2 of my original post. See the photo above, it is identical. $65 Sold
Then 2 sets from a different back billet. I will post one photo since both sets look exactly the same. These sets have sides 5 1/2 by 34, sanded to .090. Backs are very large and sanded to .130
These are $55 each Available
6 additional quartersawn Honduran mahogany scarfed peghead neck blanks
These are the additional 6 that I mentioned in my first post. Same as the first ones except 30" long. $20 each. All Sold, But I still have 8 of the off-quarter ones available at $12.50 each, these are now all sold
That's it for now. I will need some time to get caught up with everybody's totals and shipping. Please PM me your address, etc. Thanks
Grant
PostPosted: Mon Oct 15, 2007 1:05 pm
Grant, I will take 2 of those tops please. If there is any difference in them then the ones which are stiffer across the grain please. Thanks!
Burton
Burton
Brookline, MA.
PostPosted: Mon Oct 15, 2007 8:55 pm
Hi Grant, please add two dozen of the ebony bindings to my order. Pick the ones with the most stripes, please!
I'll reserve one of the $125 coco sets too if that is OK.
PostPosted: Mon Oct 15, 2007 10:26 pm
Grant,
Please add 1 dozen of the striped ebony bindings (Like Arnt, I don't mind a few stripes either) and 1 dozen of the Bocote bindings to the pre-swap meet order I have with you. Oh and an ebony doggy bag would be cool too.
PostPosted: Tue Oct 16, 2007 12:22 am
One more request from me (I could ask in the WTB thread, but since I'm already getting some stuff from you the combined shipping makes sence):
Do you have a couple of nice ziricote fingerboard and bridge blanks?
PostPosted: Tue Oct 16, 2007 2:01 am
Arnt, I will check on the ziricote fingerboard and bridge blanks, I think I have a couple. I will have the photos of the $125 coco sets up this afternoon. You get first pick.
Got it, Kim.
Grant
PostPosted: Tue Oct 16, 2007 2:33 am
I'll take a dozen of the ebony bindings too and I am interested in the $125.00 coco sets too.
