It is currently Fri Jun 06, 2025 9:23 am
PostPosted: Thu Oct 18, 2007 3:13 am
Finished my first build and had the treble side sounding tin-ny / slightly buzzy. I did a search and found the thread on the fret leveler, boy it worked great, Thanks Rick !! I had 220 adhesive back paper, but I'm having trouble finding 320 and 400 locally, I'm up in the mountains (snowy I might add). I'd like to find these in sheet with the adhesive back as a roll will be $20 or so and it will be eight lifetime supplies. Has anyone use a product that you can spray on the back of a sheet product or know of a sheet product that come with the adhesive already on it.
Peter
PostPosted: Thu Oct 18, 2007 4:42 am
[QUOTE=ToddStock] OK...spelling not so hot today...I'm drying out from post-op pain killers, so please ignore...[/QUOTE]
Todd, what'd they cut off ya? Here's hoping for a quick recovery!
PostPosted: Thu Oct 18, 2007 1:35 pm
I use my 6 inch PSA discs, works like a charm, 220 and 320.
Matter of fact, I now use the 320 on my Stanley Plane Body instead of sandpaper wrap like Frank taught me. I like the PSA papers, and I simply squared the side, and used two slices to make the 14 inches. I may have used two discs, hmmm, you'll figure it out, it doesn't have to be continuous rolls.
PostPosted: Sat Oct 20, 2007 3:08 am
The problem I've found with spray adhesives is in getting the paper back off once its worn out. After two years of heating & picking & scraping off glue... I just spent the bucks on Klingspor & 3M Gold PSA abrasive strips. The 3M Gold is my fave.
PostPosted: Sat Oct 20, 2007 7:50 am
Todd,
Hope you start feeling better soon. I had a partial Knee replacement, ACL and lateral meniscus all at once about a year ago, I'm just getting around without pain.
Good Luck with your recovery, hopefully it won't be that long for you.
Peter
