It is currently Sun Sep 14, 2025 10:18 am
PostPosted: Fri Nov 16, 2007 2:51 pm
Bummer, I know they worked on this case too to get it right. Maybe they went back to the first set of plans?
I got a chuckle at my old job. They'd gone back to a set of student drawn plans from a previous year. Those headers for the closets sure looked funny at 6'0", which was a typo for 6'8", the industry standard door.
Stuff happens.
PostPosted: Fri Nov 16, 2007 3:23 pm
I have made 3 OLF SJ's and they all have fit nicely into Ameritage cases. It is tight, but not so tight that I'd ever be worried about the finish.
PostPosted: Fri Nov 16, 2007 5:26 pm
Ameritage cases are pretty snug.
PostPosted: Mon Nov 19, 2007 2:20 am
Bruce:
Nope the Original was actually their standard AME-32 It is for a longer body. It was never too tight.
Todd:
The Model # for a fitted OLF SJ AME-32OLF. I have them build them to custom interior and exterior fabric specs for me. I have 9 in clients hands and 4 More in stock all fit perfect.
I sent them the body form they use. I suppose it is possible the foam could be over thickness or out of spec on one now and then
As long as the foam is not noticeable compressing I would not worry too much as the foam has memory and will settle in to the shape over a short time frame.
PostPosted: Mon Nov 19, 2007 3:00 am
I have heard that a very snug fit is better if you ever trust the guitar to a public carrier. If the guitar moves in the case even a little, it is supposedly more susecptible to neck damage. No personal experience, though.
PostPosted: Mon Nov 19, 2007 3:35 am
That is right
PostPosted: Mon Nov 19, 2007 4:22 am
My Ameritage cases fit better than the Cedar Creek I used to get but I send the tracing 1/4 inch oversize just in case.
Ken Franklin
clumsy yet persistent
PostPosted: Mon Nov 19, 2007 4:42 am
One thing I have noticed. My case use crushed velvet interior instead of the standard plush (hairy looking stuff) that comes in the retail market Ameritage cases.
I notice that the guitar slides into the case easier with the crushed velvet even with a tight fit.
PostPosted: Mon Nov 19, 2007 4:52 am
1/4" oversize?!?  May as well not use a case...
Most of the protection of a good case comes from a tight fit. Whe n dropped, the case dissipates the impacts' energy, protecting the guitar from any direct energy; if the guitar can move inside the case, there is a second impact, and that is the guitar impacting the interior of the case. Therefor, the guitar still must dissipate direct energy on its own.  Same as wearing a loose seatbelt or wearing a I'll fitting helmet won't do a dang thing in a big wreck.
If I had a mechanical scale nearby, I'd measure how many pounds of force it takes to set my guitars in their Calton cases, but it's over ten pounds, I would bet. A hand gently pushes at the tail block, while the other holds the neck, up close to the body joint. Once in there, I can carry them around with the lid open and nothing budges. I wouldn't fly with any looser of a fit...
I assume that by the time y'all are spending enough for a Ameritage case, you are seeking better protection or a better fit than you would get from a double-arched, 5 ply TKL that costs 1/4 as much, right? Now, if you order it for a nice loose fit, you've tossed all that away, and all you have is a pretty, and expensive, case that offers little  real-world protection.
PostPosted: Mon Nov 19, 2007 2:19 pm
The TKL cases I have gotten for my 18" archtops are very snug,but they "break-in" as the guitar is taken in and out-the foam and fabric compress a little.
PostPosted: Mon Nov 19, 2007 5:32 pm
This may be slightly off topic, but how long does it take to get your cases after ameritage ships them? Mine are supposed to be shipped this week and I am getting tight on delivery dates to the customers.
PostPosted: Tue Nov 20, 2007 1:22 am
There is two shipping dates. First from the plant to the warehousein the states and then from the warehouse to you. My orders tend to get to me with in 10 days fro leaving the plant or 2-3 days from the time they get to the states side warehouse
PostPosted: Tue Nov 20, 2007 10:26 am
Nancy called this morning and gave me a tracking number for the cases. Looks like UPS should deliver them on Monday.
Thanks yall!
